Wastegate routing question
Old Apr 9, 2016 | 04:30 AM
ramboPandA's Avatar
Default Wastegate routing question
Hey was just wondering if I can weld my wastegate dump tube into my test pipe. Is that to far down stream? Because I do not want to cut into my down pipe
Old Apr 10, 2016 | 04:03 PM
VegaS10's Avatar
Default Re: Wastegate routing question
Why don't you want to go into the down pipe?
Old Apr 11, 2016 | 10:15 AM
Schister66's Avatar
Man U FTW
That's a really long way to run it and I can't think of a good reason why you wouldnt either tie it into the dp earlier or just run it to atmosphere. This seems overcomplicated with no good reason as to why..
Old Apr 12, 2016 | 08:42 AM
SovXietday's Avatar
I'm guessing you want to put it in the test pipe because it's a relatively cheap piece of steel and easily replaceable if something doesn't go right?
Either way, yes it's fine.
HIGHLY suggest doing two things.
1) Add a flex joint. You will crack the dump tube or break the wastegate off the manifold otherwise.
2) Add a vband/flange in the middle of it somewhere. You will have a hell of a time ever disconnecting anything if you don't.
Scott53092
Mar 16, 2013 07:52 PM
dartonh22
Welding / Fabrication
15
Jul 16, 2008 03:18 PM
HamiltonRex
Jan 30, 2006 06:15 PM
importimage
Jul 13, 2003 09:56 AM
