HELP: Cam gear removal
Old Oct 4, 2004 | 01:25 PM
Haleiwa-Brando's Avatar
Default HELP: Cam gear removal
I used the search button, and searched on google and came up with nothing. There weren't even detailed directions in the helms manual .
Basically what I need is, instructions on how to get those little bastards off. I'm driving myself mad, and I don't want to do any damage do the engine. Engine is a B18C5.
Thanks for the help.
Old Oct 4, 2004 | 03:07 PM
IN VTEC's Avatar
Default Re: HELP: Cam gear removal (Haleiwa-Brando)
If you can get an impact gun (pneumatic or electric) in there with a shallow 1/2" drive socket, then I'd do that.
A lot of times, I resort to simply removing the cams and then using the impact.
Old Oct 4, 2004 | 03:12 PM
drdisco69's Avatar
Assuming the timing belt is still on, put a socket on the crank pulley and have someone hold it. You can then use a 14mm on the crank pulley bolt. Alternatively, wrap a (large) screwdriver in a rag and put it through the hole in the cam gear and brace it (gently) against the head. The first method is a little nicer.
PY2KITR1060
Jul 26, 2022 06:12 AM
rockinsbs
Engine Management and Tuning
11
Sep 12, 2009 11:45 AM
BigPlansNoMoney
Sep 25, 2007 12:53 PM
jtchinoy
Jun 24, 2006 11:02 PM
Civicman86
Jun 22, 2006 10:01 AM
