Problems with Probe Rods??
Old Oct 3, 2004 | 09:14 PM
earl's Avatar
Default Problems with Probe Rods??
I had a customer give me a set of Probe GSR rods as part of a build. When installing the bearings they didn't fit right, pretty much offset.
When putting together, I got this offset
Are all Probes like this?
Old Oct 3, 2004 | 09:26 PM
GumballNA's Avatar
Default Re: Problems with Probe Rods?? (earl)
talk to jeff from IB, I think he deals alot with Probe, or maybe they gave the guy the wrong rod's? I have seen probe rod's in person with the bearings, and they fit fine... but maybe it's a mistake. But Jeff from IB deal's with them alot I believe, but im not too sure.
B20Monster's Avatar
i had the same problem with the probe rods. you either have to get them notched to fit the gsr bearings.. or use LS bearings.
Old Oct 3, 2004 | 09:31 PM
earl's Avatar
Default Re: Problems with Probe Rods?? (B20Monster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20Monster &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem with the probe rods. you either have to get them notched to fit the gsr bearings.. or use LS bearings.</TD></TR></TABLE>The problem with doing that is the edge of the bearing binds against the rod journal radius. How can those rods be so far out of spec and why would anyone trust that the rest of the rod is any better...
Old Oct 3, 2004 | 09:43 PM
b19coupe's Avatar
I got a set of Probe rods with the same offset. Could not bring my self to run them. Traded for something else.
Old Oct 3, 2004 | 11:10 PM
earl's Avatar
Default Re: Problems with Probe Rods?? (b19coupe)
Yeah, I put my customer in a set of Manleys and he was happy.
Old Oct 3, 2004 | 11:25 PM
4piston's Avatar
Wow. I've never seen anything like that. It really pays to spend the extra dollar on good parts.
Old Oct 4, 2004 | 04:58 AM
1 2 NV's Avatar
ive personally never used probe rods and after seeing this post im glad i havent. bump for good info earl.
Old Oct 4, 2004 | 05:03 AM
BERT-O's Avatar
whoa..............and I thought Probe was suppose to be the ****, mang!
Old Oct 4, 2004 | 06:49 AM
bigTom's Avatar
iv encoutnered this and as far as i can recall it wasnt the rods but the bearings... i think i put stock bearings in and they were fine...
i really dont remember though as this was a while ago
actually yea it was... they were stock rods w/ acl bearings
Old Oct 4, 2004 | 11:21 AM
Odiedogcx's Avatar
AIRBORNE
Default Re: Problems with Probe Rods?? (ek9t)
So is it the Probe Rods or ACL Bearings?
I know some people have talked about fitment issues with some of the ACL bearings, but B20Monster also said he has the same problem with the rods.
I know Earl is a strong supporter of the ACL bearings, and i'll soon be using them .. so i'm interested in what he, and other people have to say.
Old Oct 4, 2004 | 11:30 AM
b19coupe's Avatar
Default Re: Problems with Probe Rods?? (Odiedogcx)
In my case it was the rods for sure. I was using OEM bearings.
Old Oct 4, 2004 | 11:40 AM
Odiedogcx's Avatar
AIRBORNE
Well then, that for the most part throws out the ACL Bearing "variable"
Old Oct 4, 2004 | 11:52 AM
H22coupe's Avatar
Is that offset due to using a gsr rod bearing in an ls bearing application? I know the two bearings are different widths just never compared them side by side. If not, could someone throw up a pic showing the difference between the two?
Old Oct 4, 2004 | 11:53 AM
bigTom's Avatar
just popped into my head... it might of had something to do with the fact of the bearing being ls/gsr/b16... once again... i completely forgot... im just trying to remember what the problem ended up being
Old Oct 4, 2004 | 12:13 PM
TOM J's Avatar
Old Schooler
It looks to me like you have a single cam VTEC bearing in there you may want to check.
I had a couple of ACL boxes with the wrong bearings in them so you may want to double check.
They look simular but the offset is a little difrent.
I even had single cam VTEC and GSR bearings in the same ACL box.
Old Oct 4, 2004 | 12:53 PM
earl's Avatar
Default Re: Problems with Probe Rods?? (TOM J)
Because of the rod length, I know they were a Probe GSR rod. GSR rod bearings are .079" more narrow than the LS bearing. Maybe that would have helped the situation some to use LS bearings but I don't think they would be wide enough to make the bearings align properly. Crazy rod...
Old Oct 5, 2004 | 10:24 PM
TRAN's Avatar
wow gezz I'm never going to think about buying probe rods!!!!
Old Oct 13, 2004 | 06:57 PM
evilxkid's Avatar
Default Re: Problems with Probe Rods?? (Zigga)
i had a set of probe rods like that. they where for a gsr. i did use ls berings and it ran fine, and i raced the hell out of it.
probe originaly made ls rods, so i think they just shortened them and called them gsr rods. i guess a larger bering could be good for heat distrabution from the rod.
that's funny earl, i sent you an iIM a long time ago about trying to use ls berings in a grs cause i had the wrong berings, but then when i got my rods the ended up working out straingly enough.
EGUK
Oct 25, 2006 02:08 AM
turbocivic0618
Apr 16, 2006 10:36 AM
Muckman
Dec 19, 2005 10:27 PM
done
Nov 6, 2004 06:01 PM
yellowmonkeyboy
Nov 4, 2004 11:46 AM
