What's the best engine oil for Honda's VTEC engines ?
Old Oct 3, 2004 | 06:50 PM
SiR Inspired ED7's Avatar
Default What's the best engine oil for Honda's VTEC engines ?
I got this from >>> http://asia.vtec.net/topics/oil1.html
i was searching for the best motor oil for a honda and this is what i found for my all the Honda-Tech Famliy!
The official Honda engine oils, "Honda Engine Oil" on the left is semi-synthetic while "Honda VTEC-LEV" on the right is mineral.
One question that have always been asked whenever Honda fans discusses about VTEC is that issue of the best engine oil for the engine. While there are many different brands of oil available on the market, many with great specifications, some even with a "Formula-1 Pedigree" (e.g. Mobil-1), I think the answer by Mr. Ichisima, president of the famous SPOON SPORTS Honda specialist tuner in Japan during his interview on issue-1 of BEST MOTORing International, is the best and most concise. Mr. Ichisima said it simply for engine oil, the "price per litre" is no indication of suitability, i.e. a multi-dollar oil will not necessarily work better than the cheaper alternative. He goes on to make a firm recommendation for the best engine oil for your Honda engine, the oil available from the dealer is probably the best. Personally, I think his recommendation makes the best sense.
Honda Engine Oil
Honda VTEC-LEV oil
In the Malaysian market at least, Honda officially markets two grades of engine oil. The "Honda Engine Oil" is a semi-synthetic 15W-40 oil which is recommended for all Honda engines, including the super high spec'ed DOHC VTEC and DOHC iVTEC versions. The Honda "VTEC-LEV" engine oil is meant for the low-emissions rated engines, e.g. D15B 3-stage VTEC or the D17 on the new Civic. This oil is mineral and is spec'ed at 10W-30. Owners of Hondas will most probably not go wrong with either of these oils. Based on the information on the packaging, for most SOHC engines, Honda's VTEC-LEV oil seems to be the best recommendation. For the DOHC and DOHC-VTEC engines, Honda's "Engine Oil" will probably be the best recommendation. However, it would be best to consult the dealer when making the decision on which engine oil to use for the car. The packaging listed "Idemitsu" as the OEM manufacturer of these oils, most probably manufactured to Honda's unique specifications, just like what OKI do for micro-controllers for Honda's ECUs.
I myself have since switched from Shell lubricants to Honda's "Engine Oil" on my Integra. With Honda's "Engine Oil", the engine now seems much quieter and smoother at idle, with a clear feeling of "lightness" when asked to rev to high rpms (which is probably due to the lighter 40 weight as compared to Shell Helix Plus which has a weight rating of 50). The engine note is much more race-like with a much clearer distinct change in note at the VTEC changover point. For my EK3's next service, I again intend to switch from Shell Helix Plus semi-synthetic, this time to Honda's "VTEC-LEV" engine oil. Personally for me, Mr. Ichisima's recommendations were on the spot, and I would recommend to readers to try them out for themselves too.
Note : Recommendation with regards to which engine oil to use on this article are the personal opinions of the writer and are expressed "as-is" and purely as an opinion only. Readers should use their own judgement when deciding on which engine oil they should ultimately use for their car.
Old Oct 3, 2004 | 08:45 PM
seek167's Avatar
Default Re: What's the best engine oil for Honda's VTEC engines ? (-=*Dusk2Dawn*=-)
group buy, for the jdm oil good find
Old Oct 3, 2004 | 10:12 PM
gamakichi77's Avatar
Default Re: What's the best engine oil for Honda's VTEC engines ? (seek167)
it is IDEMITSU oil actually......just the bottle is different...oils is from the same producer.......
Old Oct 4, 2004 | 06:48 AM
civicross's Avatar
I would like to see some used oil analysis data on this before debating wether or not an oil is better than another by the "sound of the engine."
Old Oct 4, 2004 | 07:06 AM
nickgomez's Avatar
Default Re: (civicross)
Here we can get VTEC LEV (Mineral), Semi Synth and now Fully Synthetic Honda Genuine Oil. Supplied to Honda Malaysia Sdn. Bhd. by Idemitsu.
Old Oct 7, 2004 | 10:20 PM
Ohsofast's Avatar
Default Re: (nickgomez)
Change your oil frequently enough and use the cheaper stuff, far better that than running expensive oil to long. Or forgetting to put back in your drain plug and seeing a very expensive mess under your motor.
Old Oct 8, 2004 | 04:27 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (Ohsofast)
I use Valvoline SynPower...
I'm thinking about going with Amsoil on the next change, or mabye some RP41
http://www.amsoil.com/performa....html
http://www.bestsyntheticoil.co...3.pdf
Synpower seems to be the best readily available oil out there...
Old Oct 8, 2004 | 06:30 AM
bruthaboost's Avatar
Default Re: (LSVTEC 91 Civic)
I used conventional pennzoil for 135k mi and when I tore down the motor for FI build up, the bearings were in outstanding condition. My neighbor thought they were the new ones. .
Old Oct 8, 2004 | 02:18 PM
Bandit74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -=*Dusk2Dawn*=- &raquo;</TD></TR><TR><TD CLASS="quote">
Blam!
Old Oct 8, 2004 | 02:30 PM
Banned
Default Re: What's the best engine oil for Honda's VTEC engines ? (Bandit74)
I would not buy a motor oil just because it says "VTEC" On the bottle.
Old Oct 9, 2004 | 12:10 AM
nickgomez's Avatar
Default Re: What's the best engine oil for Honda's VTEC engines ? (LSVTEC 91 Civic)
Don't buy it cos it's 'JDM' or whatever! Good oil, frequent changes = longer engine life.
Old Oct 9, 2004 | 12:22 AM
Sack Master's Avatar
Default Re: What's the best engine oil for Honda's VTEC engines ? (nickgomez)
I don't think a 94 gs-r is LEV so I guess that counts me out. I'll stick with my valvoline. It hasn't failed me yet.
Old Oct 9, 2004 | 08:27 AM
Banned
Default Re: What's the best engine oil for Honda's VTEC engines ? (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">I don't think a 94 gs-r is LEV so I guess that counts me out. I'll stick with my valvoline. It hasn't failed me yet.</TD></TR></TABLE>
Valvoline isn't a bad dino oil, but synpower 10w30 is a much better product.
subrata1972
Honda Motorcycles
May 23, 2017 05:45 AM
alexandre-zion
54
Aug 21, 2012 10:10 PM
virgstyle
Jun 23, 2006 09:16 AM
RoverHondaman
Aug 3, 2005 07:13 PM
