tranny welding...help
Old Oct 3, 2004 | 03:46 PM
pane93civhb's Avatar
Default tranny welding...help
ok think of a b series tranny rear mounting area the lower bolts have broken through the bell housing so there for i can not bolt anything there how would, or would anyone think it possible to maybe weld and re drill the holes and it be sturdy enough for race or should i just try to find a new bell housing. sorry for the punctuation. im trying to leave work. thanks for all the help if anyone responds.
Old Oct 3, 2004 | 05:49 PM
S9i1R's Avatar
Default Re: tranny welding...help (pane93civhb)
just JB weld it and in the mean time look for a new bell housing.
Old Oct 4, 2004 | 09:40 AM
Default Re: tranny welding...help (S9i1R)
i dont have the pieces of the bell housing that fell off though just the bolts that came off later.
Old Oct 4, 2004 | 01:17 PM
S9i1R's Avatar
I saw a post on here not too long ago, the guy had the same problem as your having, he used some silly putty to make a mold and then stuffed some JB weld down in there and re-tapped it. he said it held together. I think it's in the post is in the weld/fab. form
Old Oct 5, 2004 | 07:09 AM
i will try to check it out i guess since i have an aftermarket motor mount kit that may be strong enough.
Old Oct 5, 2004 | 08:07 AM
mmuller's Avatar
Mad Scientist
just take it to a place that can weld al. well and they'll fix it.
have done it to mine
Old Oct 5, 2004 | 09:09 AM
Default Re: tranny welding...help (mmuller)
how much did they charge u to weld it and retap it also.
Old Oct 5, 2004 | 04:01 PM
S9i1R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">how much did they charge u to weld it and retap it also. </TD></TR></TABLE>
it all depends, it should only take 1-2 hours, how much for labor and supplies. at the most I'd say $100?
Old Oct 5, 2004 | 06:21 PM
mmuller's Avatar
Mad Scientist
they did 2 bolt holes+ tap for $75 if i remember right
Old Oct 6, 2004 | 02:07 PM
Doctor CorteZ's Avatar
have it welded , any welding shop can do it.
Old Oct 6, 2004 | 03:17 PM
Default Re: tranny welding...help (Doctor CorteZ)
how much do u think they will try to get me for.
doublethink
Sep 13, 2007 02:35 PM
integra95gsr
37
Feb 22, 2006 07:02 PM
IntegraTypeR
Apr 28, 2005 12:18 PM
zman
Welding / Fabrication
Apr 15, 2005 02:04 PM
shortyz
22
Jan 4, 2003 01:39 AM
