to weld or not to weld
Old Apr 12, 2005 | 04:20 AM
zman's Avatar
Default to weld or not to weld
I need peoples advice on whether or not i should just get my tranny aluminium welded, drill a new hole, and tap some new threads?
I've got mixed opinions so far from the people i've spoken to.
Old Apr 12, 2005 | 01:31 PM
ferio 95's Avatar
Default Re: to weld or not to weld (zman)
**** that same **** happend to me. it cant be welded from what ive been told. im hoping someone can prove that wrong cause my top and bottom bolt hole is messed up just like that
Old Apr 12, 2005 | 06:18 PM
GSRoadRage's Avatar
I'd say weld it up redrill it and tap it. Done alot of tranny's out here in CA like that, havn't had a problem welding one yet. Welding a block now that is a problem... but never had a problem welding up a alum tranny or oil pan.
Any idea why it tore out like that? broken motor mount maybe? If you don't find the reason a repair will just tear out the same again.
Old Apr 12, 2005 | 11:44 PM
zman's Avatar
Default Re: to weld or not to weld (GSRoadRage)
well the place who did my swap used the wrong rear mount so only 2 of the 3 bolts that hold the mount to the tranny were used. So obviously it caused way too much strees on that bolt and it took a chunk of the tranny out.
Old Apr 13, 2005 | 05:46 PM
GSRoadRage's Avatar
ouch, I'd say unless you fix the mount issue and use all 3 bolts, there is no point in fixing the tranny as it will just break again. Good luck .
Old Apr 15, 2005 | 02:04 PM
hybridmoments's Avatar
what you need is a nice 1/2" thick piece (block) of aluminum. make sure you bevel the trans side and the piece you are welding in. that way you can get really nice penetration.
then tig weld it. you will probably need something with around 200amps output or else you are going to have to do quite a few passes
once it is weld. drill and tap . in my opinion that fix would hold up nicely as long as you prepared and welded it properly
transpar_nt
Dec 3, 2005 12:17 AM
Nerologic
11
Jun 21, 2004 12:39 PM
ki11a8ee
Mar 12, 2004 05:51 PM
hydroflip
Feb 26, 2003 01:37 PM
