zex bottle hearter not that hot??
Old Oct 2, 2004 | 07:10 AM
accord2nv's Avatar
Default zex bottle hearter not that hot??
i installed the zex bottle heater and it doesn't get that hot it starts to heat up then it turns off could it be because i need more n02
Old Oct 3, 2004 | 03:07 AM
Steed77's Avatar
Default Re: zex bottle hearter not that hot?? (accord2nv)
sounds like a relay problem to me. Also look at the wire gauge. good luck
Old Oct 8, 2004 | 04:55 PM
Greenery18's Avatar
Default Re: zex bottle hearter not that hot?? (SilverGhost)
I just bought the same bottle heater and am unhappy with it. It turns itself off @ 85 degrees no matter what, so if you have half of a bottle or less you are screwed. The highest you will ever see is like 800psi. The Zex heater is good for a freshly filled bottle, or constant spraying, but sucks for half-empty bottles. I am using 2 heaters right now for this reason...
Old Oct 9, 2004 | 02:53 AM
Steed77's Avatar
Default Re: zex bottle hearter not that hot?? (Greenery18)
NX all the way!
Boner_Ben
Apr 28, 2006 08:16 PM
HatchedGTI
Apr 27, 2004 09:49 PM
tegon-gsr
Jan 4, 2004 11:26 AM
tek_civic
10
Dec 18, 2002 01:34 AM
