What's the thread pitch for this oil feed on?
Old Oct 2, 2004 | 01:43 AM
AzntaggeR's Avatar
TSPeed Factory
Default What's the thread pitch for this oil feed?
its a T3/T4e if that helps. so far i put a male -3AN and a 1/8 NPT in there and they both seem to fit the same, but i want the correct fitting for it.
i checked Flamenco-T's thread and it didn't state it.
Old Oct 2, 2004 | 04:14 AM
RedTT's Avatar
Default Re: What's the thread pitch for this oil feed? (AzntaggeR)
it should be 1/8npt. Do not use -3an, they are not intended for sealing that way.
Old Oct 2, 2004 | 08:00 AM
Bailhatch's Avatar
Default Re: What's the thread pitch for this oil feed? (RedTT)
1/8" NPT is correct
Old Oct 2, 2004 | 01:28 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: What's the thread pitch for this oil feed? (Bailhatch)
are you guys positive? because i'm trying to screw in a 1/8NPT and it doesn't even go in all the way. it gets stuck like halfway through.
Old Oct 2, 2004 | 04:02 PM
Bailhatch's Avatar
pipe thread is tapered, so as you tighten it is gets tighter. Usually you can only get it in like 5 or 6 turns. your all set. just don't overtighten it or it will strip.
Old Oct 2, 2004 | 04:16 PM
AzntaggeR's Avatar
TSPeed Factory
ok i'll just thread in the 1/8" NPT then. maybe i'll use teflon tape too, but i just hear stories of it getting sucked through the system and then clogging a line.
Old Oct 2, 2004 | 04:35 PM
Bailhatch's Avatar
start the tape a few threads up or use the paste type of white pipe sealant. Or you can use RTV silicone sealant/adhesive.
RTW DC2R
Sep 10, 2006 02:36 PM
asianspeed
Oct 29, 2005 02:06 PM
boosted_zc
Jul 13, 2003 09:02 PM
SI_DRIVR
Feb 4, 2003 08:11 AM
blowncivichb
May 11, 2002 08:01 PM
