clutch problem HELP!
Old Oct 1, 2004 | 06:01 PM
JDMaccord95H22's Avatar
Default clutch problem HELP!
i found the leak in the system, but i have no idea what this part is or if it can go bad. i changed the slave cylinder yesterday and found out later than wasnt the problem. i think im gonna put some teflon tape on the threads of the fittings in the second pic.
so, i am wondering what this part is? can it go bad? it is located on the passenger side of the engine bay.
Modified by JDMaccord95H22 at 7:11 PM 10/1/2004
Old Oct 2, 2004 | 07:14 PM
ttt
Old Oct 2, 2004 | 07:27 PM
earthworm's Avatar
Default Re: (JDMaccord95H22)
Some hydraulic device with the brake system.
Do not use tape on these threads.
These appear to be compression fittings.
Monitor the fluid levels, etc, etc.
With Saab in '67 and on, I would rebuild the slave cylinder, an easy job, inexpensive..
But I would have to see the leak..
Old Oct 2, 2004 | 11:36 PM
HAccord96's Avatar
Default Re: (earthworm)
The object in the first pic looks like a clutch damper but I could be wrong.
Old Oct 3, 2004 | 01:17 PM
JDM_CD7's Avatar
Default Re: (HAccord96)
It is the clutch damper, mines went out not so long ago. I just added a lil Hondabond at the ends and bingo, Good as new
Old Oct 4, 2004 | 10:08 AM
Turbowa's Avatar
Default Re: (JDM_CB7)
Hondabond is golden
br3ak3r84
Nov 5, 2007 08:12 PM
br3ak3r84
Nov 4, 2007 04:50 PM
DewtheDu88
Feb 8, 2006 05:56 PM
DragII
Oct 27, 2004 06:06 AM
