Anyone running an oil restrictor on a -3AN oil feed line?
Old Oct 1, 2004 | 04:57 PM
AlphaKennyWun's Avatar
Default Anyone running an oil restrictor on a -3AN oil feed line?
Set up: SC 61 turbo/B18c.
Im replacing my -4AN line with a -3AN line due to oil consumption (oil being pushing passed the turbo seals). Will the -3AN be enough oil restriction alone or should I add the oil restrictor on top of that? The oil restrictor I have is a #72 or #74 NOS jet (I forget which one).
Old Oct 1, 2004 | 04:58 PM
Boostage's Avatar
Default Re: Anyone running an oil restrictor on a -3AN oil feed line? (Turbo Chris)
I think u only need a restrictor for bigger than -3AN
Old Oct 1, 2004 | 05:10 PM
Default Re: Anyone running an oil restrictor on a -3AN oil feed line? (Boostage)
cool thanks. less work for me.
Old Oct 1, 2004 | 08:09 PM
96y7turbo's Avatar
i have one on mine.. i see 5 psi at idle and it goes over 40 at 4000rpm.. i used a needle valve... i only put one on cause i had a bad turbo before and i was just paranoid.. it only cost me 4 bucks at grainger...-3an feed for me by the way..
Old Oct 1, 2004 | 09:06 PM
92HB_HB's Avatar
Default Re: Anyone running an oil restrictor on a -3AN oil feed line? (96y7turbo)
I welded my 90 degree nipple on the turbo shut and drilled a small hole through the weld to act as my restrictor.. I forgot what size drill i used, but it's been working great so far.. btw, i'm using a 4AN line ..
I never see any smoke comin out the exhaust, or oil residue in my turbo inlet and turbine outlet...
a must, if you have MINOR oil seal problems...
Old Oct 4, 2004 | 10:24 AM
My95SlvrBlt's Avatar
Default Re: Anyone running an oil restrictor on a -3AN oil feed line? (92HB_HB)
im having a serious smoking problem now on my car, i have a 4an line, with no restrictor. im gonna convert down to a -3an line, should i run a restrictor as well? im hoping that its not too late, and that i wont have to rebuild the turbo, but we shall see. anyone else have suggestions?
Old Oct 4, 2004 | 10:28 AM
tgreaves's Avatar
Default Re: Anyone running an oil restrictor on a -3AN oil feed line? (My95SlvrBlt)
I am running an oil restrictor on my car with an3 line.. Im using an Garret/Airesearch T3..
Old Oct 4, 2004 | 11:44 AM
Default Re: Anyone running an oil restrictor on a -3AN oil feed line? (tgreaves)
what kinda restrictor?
Old Oct 4, 2004 | 12:47 PM
IN VTEC's Avatar
I had never seen any factory turbo'd engines' oiling systems until a couple nights ago working on a friend's SR20DET. The restrictor is placed in the banjo bolt and the oil feed hard line is probably equivalent to a -4AN line.
We've also had problems on a 3G Eclipse turbo setup when it didn't use a restrictor. It used a -4AN line.
It doesn't help the original poster, but at least it'll throw more info into the general knowledge pool.
South Bay Surfer
Jul 10, 2008 10:31 AM
boostedSI90hatch
May 16, 2007 12:26 AM
Blkteg97
Nov 16, 2004 08:04 AM
Ad4mGSR
Jul 23, 2004 01:15 PM
silverpenny
Apr 28, 2003 06:54 AM
