Brake Pad Question
Old Oct 1, 2004 | 12:25 PM
thegrayghost's Avatar
Default Brake Pad Question
I check out my brake pads recently and notice the driver's side was worn considerably, but the passenger side hadn't worn down half as much. What's up with that? Caliper problem?
Also, has anyone ever used EBC brake pads? More specifically, the Green Stuff ones? Any good? Shitty? Worth buying?
TIA
Old Oct 2, 2004 | 08:05 AM
Default Re: Brake Pad Question (thegrayghost)
Someone has to know something about this....
Old Oct 2, 2004 | 10:42 AM
rapid_roy's Avatar
There is a chance your drivers side caliper is sticking. Soon it will freeze. The same thing happened to me but on the other side.
EBC Greenstuff pads are good street pads. Better than OEM.
Old Oct 2, 2004 | 11:06 AM
skunk2eg's Avatar
Default Re: Brake Pad Question (rapid_roy)
sounds like a "sticky" caliper also....
check the brake lines all the way from the master cylander to the caliper. make sure there are no minor crakes or warping...if so replace
Old Oct 3, 2004 | 06:35 AM
Any suggestions on how to "unstick" my caliper? Any info would be appreciated.
Old Oct 3, 2004 | 07:12 PM
stareatsun's Avatar
To unstick the caliper, you replace it
Old Oct 3, 2004 | 07:32 PM
Dropped90Integra's Avatar
Yea, replace that caliper and think about the rotors, I had a similar problem and my rotors were warped even though they were smooth as anything
Old Oct 3, 2004 | 07:43 PM
gear's Avatar
actually... its a frozen slider. Its pretty common....
just get a hammer and some powerlube. Spray the slider with powerlube and break it free with the hammer...should be back to normal...
Old Oct 3, 2004 | 08:02 PM
Brian_TII's Avatar
Default Re: Brake Pad Question (gear)
After freeing the slider pin, don't forget to use a heavier duty grease (I like high temp silicone grease) to lube everything back up again... otherwise you'll be doing this again soon.
user 93082343
14
Mar 23, 2009 02:49 PM
lude1888
Jul 3, 2006 08:59 AM
b16a2EBP
Mar 3, 2006 07:09 PM
acuraLSSE95
Jul 28, 2003 06:39 AM
integra0260
Oct 21, 2001 08:09 AM
