quick question, f22b2 block, obd2 obd1
Need an answer real quick. Can anyone confirm if an obd2 f22b2 block the same as the obd1 f22b2 block? Will a 94-95 f22b2 head bolt up to a 96-97 block and function just like normal? Using an obd1 ecu of course.
I don't think the two blocks are different but I'm not 100% sure.
Bump for you though because I wouldn't mind knowing for sure.
I believe that they are the same, but some of the sensors have different plug ends. Which wouldn't be hard to correct. Only real way of knowing is to set the two side by side and look.
the two blocks are the same but the obd2 has the crank sensor down by the oil pump. i put an obd1 into my obd2 car and i had to do some rewiring for that and still have a CEL. besides that the motor dropped right it.
osbunjosh
Mar 26, 2012 06:39 PM
