Quick Brake Pad Install Question
Old Dec 12, 2001 | 10:47 PM
onyx00's Avatar
Default Quick Brake Pad Install Question
In terms of the shims; do I need to buy new ones, or can I resuse the old ones? I am going from stock pads to Hawk HP+ pads. Also, where do I get the grease to put between the shims and the brake pads?
Thanks.
Old Dec 13, 2001 | 02:30 AM
yoshi234's Avatar
I shoot brides
Default Re: Quick Brake Pad Install Question (onyx00)
just reuse the shims.
as for grease, I use hi temp antiseize from Pep Boys. (hint: use very little, or else the chit will get squeezed out the sides and make a mess)
yoshi - who got up 3:30 am just to answer this post
Old Dec 13, 2001 | 04:05 AM
BudMan's Avatar
screw the shim - it'll tend to squeeze out after some drive time....several of us run the HP+ without the shim & there is no problem.
As for the grease - it goes between the arms of the caliper & the back of the pad (for the outside) and the caliper piston and the back of the pad (for the inside). This keeps a dry metal-metal contact from happening. $3 for a tube of synthetic brake grease to keep in your track goodie bad {a wet box for ammunition works great for taking all the oil/grease/anti-seize/etc to the track without worrying about leakage!}
Hope this helps.....Yoshi - get to sleep!
jeff
Old Dec 13, 2001 | 06:12 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
wow.. you guys actually use grease? hehe never done dat before.
BudMan: I think I'm going to start running hawk blues in the back.. at least blacks....
Old Dec 13, 2001 | 06:19 AM
Yell00ITR's Avatar
Default Re: Quick Brake Pad Install Question (Dave-ROR)
Just make sure NOT to put the grease on the pad surface, only the backing!
For the most part, I chuck the shims. They arent there for much except to help reduce noise. I simply put some grease (moly grease or mobil 1 synthetic grease) on the pad backing where the arms of the caliper hit and I am good to go.
Old Dec 13, 2001 | 06:24 AM
Willard's Avatar
Default Re: Quick Brake Pad Install Question (Yell00ITR)
After blistering (napalming) my set of shims... they look like crap anyway.
Will
-who can hardly hear the brakes over the motor..
Old Dec 13, 2001 | 08:49 AM
nsxtcjr's Avatar
New User
Default Re: Quick Brake Pad Install Question (Willard)
It's NOT antiseize. It's antisqueal compound, made specifically for this purpose. You can get it at any auto parts store.
[Modified by nsxtcjr, 11:50 AM 12/13/2001]
Old Dec 13, 2001 | 10:23 AM
Yell00ITR's Avatar
Default Re: Quick Brake Pad Install Question (nsxtcjr)
Actually, although not designed for this purpose, anti-seize works fine in this scenario.
andylawcc
Dec 22, 2009 04:00 PM
vtec128
Oct 20, 2009 07:57 AM
athoughts
Nov 17, 2005 03:12 PM
wanna b R
Sep 15, 2004 08:13 PM
tylerdurden
Jan 8, 2003 12:46 PM
