transmission problems
Old Sep 29, 2004 | 01:50 PM
97CTR's Avatar
Default transmission problems
okay, I had this engine in last year. B16b lsd tranny and everything was fine. I built it up over the winter and have just got it in.
Problem: tranny shifts fine when the engine is not running. when the engine is running and the clutch is depressed I can't get it into first, second is almost impossible and third is a little easier. I am thinking it must be something with the clutch, but I want to know if anyone has had any similar problems before I take it back out!!!!!!!
Old Sep 29, 2004 | 04:29 PM
kur0ryu's Avatar
Default Re: transmission problems (97CTR)
sounds like the clutch is not engaging all the way... I would say check the MC for the clutch? That problem happens to me on my cable tranny when I forget to adjust the tension on the cable. (stupidly it's happened twice).
Old Sep 29, 2004 | 05:48 PM
00000xxx's Avatar
I have a B16b and the same exact thing is happening to me...dont change your slave cylinder cause its not it, its either the clutch or its the MC
just one question; is your clutch chattering???
Old Sep 29, 2004 | 08:10 PM
acy76's Avatar
Default Re: transmission problems (ctr610)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr610 &raquo;</TD></TR><TR><TD CLASS="quote">I have a B16b and the same exact thing is happening to me...dont change your slave cylinder cause its not it, its either the clutch or its the MC
just one question; is your clutch chattering???</TD></TR></TABLE>
It could very well be the slave cylinder; if you just installed it, however, I would first make sure there is no air in the system.
Old Sep 30, 2004 | 07:01 AM
00000xxx's Avatar
Default Re: transmission problems (acy76)
no air in the system, i bled the line... im dropping the tranny tomorrow to figure out what the deal is im pretty sure its the clutch
Old Sep 30, 2004 | 07:07 AM
mmuller's Avatar
Mad Scientist
yeah, if the hydro system checks fine, then its most likely the pressure plate
Old Sep 30, 2004 | 12:59 PM
97CTR's Avatar
Default Re: transmission problems (mmuller)
I know its not the mc because I was driving the car last week with the stocke engine. I bled the line a few times, but the pedal still feels a little soft.......
The clutch is not chattering, I can upshift ok, but downshifting is a real chore and it works a little better when I rev match. I am thinking that the clutch fork may have slipped on one end of the throw out bearing or it could be the pressure plate, it is a new CM stage 3 clutch.
I just don't want to yank the whole motor to get the tranny out, is it really that big of a pain to do it in the car. I have had the engine out 4 times already, so its not a big deal, just want to know if there is an easier way.
Old Sep 30, 2004 | 07:01 PM
00000xxx's Avatar
i went to my last resort which is my mechanic, he said that it may just be the clutch pedal itself, he will be stopping by tommorrow so once he tells me whats going on i will share my problem because we seem to have the same problem except for the chattering i hope its just the clutch pedal in need of adjustment
allmotorkilla03
17
Jul 16, 2007 03:55 PM
B-JUSTINE
Jun 8, 2006 08:51 AM
shhh151
Sep 8, 2005 05:42 PM
manson
10
Mar 22, 2004 01:10 PM
tegrevboy
Oct 22, 2002 04:11 PM
