adjusting the clutch.
Re: (allmotorkilla03)
you adjust the pedal you dont adjust the clutch get under the dash and there is a bolt to stop your clutch adjust it to where you want the pedal to stop when depressed. there is a nut on the rod going into the master cylider turn the to adjust where the clutch grabs I believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Folgers »</TD></TR><TR><TD CLASS="quote">i belive its right near the tranny, on my cable j1 tranny it is.</TD></TR></TABLE>
His is Hydrolic not cable
Ill see if i can get a pic tonight and post it up so you can see what im talking about.
Re: adjusting the clutch. (hondamark35)
You can't adjust the engagement point on a hydraulic clutch because they are self adjusting. Pedal is adjustable though.
^^ correct^^ I adjusted my wifes pedal yesterday because she is short. I got it exactly where she needed it to be cofortable. What problem are you having? Maybee try bleeding the system. Takes 2 peeps but I do it alone....
kdsmonitor
10-13-2008 07:35 PM
jwbnavy
12
12-02-2007 06:36 PM
