lsvtec Idle hella high when i start my car!!
i dont know if this is normal, my vtec kick in at 4.5 and the ecu is from a 98 gsr. Is it chipped? I also know i have a problem with my check light engine that's on rite now, i feel vtec, i checked my oil, what can it be? PLease help me out!!!
My setup 97 ls bottom
99 b16 vtec head
type r camshafts
type r manifold
port and polish gsr throttle body
3 inch aem cold air intake
msd 6 al
act stage 3 racing clutch
vfac vtec controller
B&m fuel pressure regulator
99 b16 vtec head
type r camshafts
type r manifold
msd 6 al
uhmm.... another problem you will have with the check engine light is because of the Fuel Tank Pressure sensor. all 94-97 Tegs do not have this sensor, so even if you fix all the other problems, knock sensor.... etc... your check engine light will still be triggered by the low reading on the Fuel Tank Pressure sensor.
You should probably find another ECU for your application.
will this check light engine do anything if i race? will it hold me back or naw? thanks a lot man.
CrisEK
13
Jun 12, 2005 02:48 AM
