Blown Turbo seals?
I have had my kit on my car for a little over 2 months now, The turbo is a used Garrett 57 trim off a revhard kit. When i got the turbo it had 5,000 miles on it the car it came off of never smoked or anything crazy like that. I put it on my car and ever so often it will just start smoking out of the exhaust when i am at a dead stop, if i start moving it stops but it doesnt do it all the time maybe once a week. I have the oil return bung on the oil pan in the correct location and it is angled as well. The only thing i can think is the return line itself, it is the blue hose from atpturbo.com, everyday i check it it has an oily film on the outside of it like the oil bleeds through or something. Anyone have a problem like this? Maybe the seals are going bad i dont really know.
my car did the same thing...i never figured out what it was. but im guessing every time i came to a stop all the oil will roll to the front and clog the return line . thats just what i think it was.
There is no shaft play and no oil in the intake piping. That is why i am having trouble figuring this out. Someon just told me that i may not have enough crankcase ventilation. I am running a greddy catch can that just routes to atmosphere, should i hook it to a vacuum source?
Interesting... I have a brand new block, and the same turbo as last year, and sometime it start smoking too. But my return line as a kink in it, so last night, I fix it and put a braided hose, so now i don't have any kink. I hope that the smoke stop now... I took my car this morning to go to job, and no smoke.
I will let it run on idle tonight on my driveway.
I have done everything but switch to a braided line, but mine does not have a kink in it. Everytime i think its fixed about 2 days later it smokes then it might be another week or two before it does it again. Damn its pissing me off. It cant be the motor comp. is 220-216-220-220. I think i am gonna try to run another vacuum line to my catch can and see if that works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast94ex »</TD></TR><TR><TD CLASS="quote">I dont think so, what exactly do you mean by restrictor? My setup is pretty much the same as all the others ive seen.</TD></TR></TABLE>
Having too much oil pressure can lead to blown turbo seals. The restrictor is to reduce the oil flow and pressure from the feed line.
O16581724 5 2 5
Nov 24, 2005 09:29 PM
Elite Hatch
Oct 20, 2002 05:43 AM
