misfiring in all cyclinders...help
i went to get my car tested today and its running i think code 302 misfiring in all 4 cylinders and its running a cat code i dont remember the # though how can i fix this ive changed my plugs wires and distrubutor cap
you should do a valve adjustment, they tend to get tight after some mileage, worse case burnt valve(s) aonther thing to check if valve adjustment doesn't help is to check for a faulty injector I've replaced two injectors in two different crv's.
fit256nj
19
Feb 15, 2006 09:19 AM
ActiveAero
Jan 16, 2002 06:12 PM
