'95 Civic Coupe I need a loose stick/gearbox fix?
Old Sep 26, 2004 | 08:57 PM
NoGreenCard's Avatar
Default '95 Civic Coupe I need a loose stick/gearbox fix?
I'm about to purchase a '95 Civic EX Coupe (Canadian Branded) and when I test drove the car, I noticed that the stick was loose (Every gear could "jiggle" like it was in neutral even though I could shift into every gear without a problem.) The tranny itself made smooth solid shifts but not knowing when I was in neutral made me stall the car almost immediately. The car itself is great while in gear but I wanted to know how I could fix the shifter rod and how much it'd cost me.
Old Sep 26, 2004 | 09:00 PM
98k20ex's Avatar
Default Re: '95 Civic Coupe I need a loose stick/gearbox fix? (NoGreenCard)
put a short throw shifter in. you can do it yourself and while ur under there, u can make sure nothing is actually broke. shift linkage is prolly fine, just a little loose
Old Sep 27, 2004 | 12:06 PM
Default Re: '95 Civic Coupe I need a loose stick/gearbox fix? (98b16ex)
Okay, if I replace the shifter rod, I'd probably need to change the mounting brackets but that's about it right? There shouldn't be anything wrong with the actual gearbox and linkages to the tranny?
Hephro.T
Sep 27, 2016 11:22 PM
klnteg
Jun 12, 2009 07:58 AM
slammdcivic95
Dec 23, 2006 11:20 PM
Teal95Coupe
Dec 16, 2002 08:40 AM
dose
16
Oct 5, 2002 07:40 AM
