Cold start problem
Old Sep 26, 2004 | 02:16 PM
PowderB16's Avatar
Default Cold start problem
First off, i started seeing the problem after i installed the STR throttle body, i thought that it might be because i was running lean. I have a header, skunk-2 intake manifold with a stock fuel rail and injectors, if you can give me any advice or reason for this happening i would greatly appreciate it!
Old Sep 26, 2004 | 02:49 PM
SOHC4life 96's Avatar
Default Re: Cold start problem (PowderB16)
What is the problem?
Old Sep 26, 2004 | 03:10 PM
numbnuts22715's Avatar
Default Re: Cold start problem (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">What is the problem?</TD></TR></TABLE>
Old Sep 26, 2004 | 04:05 PM
PowderB16's Avatar
Default Re: Cold start problem (numbnuts22715)
when it starts it idles soooo low that it cuts off, i have to give it gas and keep it revved up to about 900 rpms, it is acting like a cold start only because it takes sooo long to warm up too.
Old Sep 26, 2004 | 04:12 PM
Ricey McRicerton's Avatar
Possibly your new TB doesnt have a cold idle thermo valve and your old TB did?
What motor is this on?
Old Sep 26, 2004 | 04:16 PM
PowderB16's Avatar
Default Re: Cold start problem (Ricey McRicerton)
B16a, is that the hole that the original throttle body had at the top? that the extra line went into? if so, how could i fix/bypass this problem?
Old Sep 26, 2004 | 07:41 PM
PowderB16's Avatar
Old Sep 26, 2004 | 07:46 PM
murmur9's Avatar
Old Sep 26, 2004 | 07:56 PM
PowderB16's Avatar
Default Re: Cold start problem (murmur9)
problems listed
Old Sep 27, 2004 | 03:52 AM
PowderB16's Avatar
bump
Old Sep 27, 2004 | 03:15 PM
PowderB16's Avatar
bump to keep my question alive...........
kpop
Jan 3, 2007 08:44 PM
do_0b
Dec 30, 2006 10:39 PM
boost'dsiR
12
Dec 17, 2005 01:00 AM
robpreludevtec220
May 2, 2005 01:46 PM
crxste
Oct 2, 2004 01:02 AM
