Cold start problem
Cold start problem
First off, i started seeing the problem after i installed the STR throttle body, i thought that it might be because i was running lean. I have a header, skunk-2 intake manifold with a stock fuel rail and injectors, if you can give me any advice or reason for this happening i would greatly appreciate it!
Re: Cold start problem (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">What is the problem?</TD></TR></TABLE>
Re: Cold start problem (numbnuts22715)
when it starts it idles soooo low that it cuts off, i have to give it gas and keep it revved up to about 900 rpms, it is acting like a cold start only because it takes sooo long to warm up too.
Re: Cold start problem (Ricey McRicerton)
B16a, is that the hole that the original throttle body had at the top? that the extra line went into? if so, how could i fix/bypass this problem?
Re: Cold start problem (PowderB16)
