couple of ?'s 91 crx hf -swap
Old Sep 25, 2004 | 09:45 PM
civicdust's Avatar
Default couple of ?'s 91 crx hf -swap
alright after a long time, i decided to drop the b16 myself. i dont work, so all i have is time
anyways, i dropped the sucker in (jdm b16a), and bolted it in tight.
as i was plugging things in, i noticed i had lots of "adapters" or "plugs" left.
ok my car is a 90 crx HF, and i THINK, im using an si wiring harness.
there all mostly near the intake manifold, and let it be known i have bought 3 intake manifolds. i will pics tomorrow.
Now, The questions:
1. why dont i have the plugs for the fuel injectors? am i suppost to buy them or should they be on the harness?
2. i need a specific diagram of the wiring (not just vacuum hose..) remember HF.
i already searched and has helped me alot. i just need those ?'s answered
Old Sep 25, 2004 | 11:25 PM
91hob20hb's Avatar
Uhhhhh. are u sure the plugs for the injectors are not there???Possibly a cut harness you are trying to use.Oh and, Yes the injector plug are supposed to be there.
Old Sep 25, 2004 | 11:42 PM
Rywire's Avatar
Default Re: couple of ?'s 91 crx hf -swap (civicdust)
us the crx hf harness. Add the second o2, vtec solenoid, vtec oil pressure, and knock sensor plugs.
Ryan
Old Sep 26, 2004 | 12:59 AM
civicdust's Avatar
Default Re: couple of ?'s 91 crx hf -swap (droppedcrxsi)
alright, i kinda get the idea of the plugs for the fuel injectors, now my main concern is hooking up green plug on the solenoid, and the one sensor coming out of it. i will get pics tomorrow.
anyone mind taking a pic of everything around the manifold? Thanks
Old Sep 26, 2004 | 01:34 AM
BoostedENG's Avatar
The HF is MPFI, you should have the plugs for injectors, no?
Someone please explain!
I'm trying to learn and help at the same time
Old Sep 26, 2004 | 02:39 AM
davens's Avatar
I've never swapped on an HF, but I have read that while the HF and Si are MPFI, there are a couple differences ibetween the two harnesses.
You said you "think" you're using an SI harness, but it's missing two plugs? Sounds like a DX harness to me...or as said earlier, the harness has been cut.
Go back and use your HF harness.
I had done some preliminary research awhile back but never finished:
http://www.effinmotorworks.com...e.htm
Old Sep 26, 2004 | 03:18 PM
civicdust's Avatar
WTF, is that green switch for?
What about this lil ******?
Look at this POS!!!
What are these 2 ********* for? fuel injectors? this is whats mainly confusing me.
someone take pics like these so i can know what wire goes to where
Old Sep 26, 2004 | 03:33 PM
89 pos's Avatar
that looks like a dx harness
Old Sep 26, 2004 | 03:49 PM
civicdust's Avatar
Default Re: couple of ?'s 91 crx hf -swap (89 pos)
HF harness. i used the one that the motor came with. it had more plugs than the hf harness
Old Sep 26, 2004 | 04:12 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdust &raquo;</TD></TR><TR><TD CLASS="quote">i used the one that the motor came with. it had more plugs than the hf harness</TD></TR></TABLE>
DONT US THE HARNESS THAT CAME WITH THE ENGINE!! Did you not read what we said? Use the one that matches the car.
The white plug that you called a lil ****** is vtec solenoid, and the green one is the vtec pressure switch, the plastic around the edges is broken off.
PS, thats a dx harness thats on your car right now, you will never get it to run with that.
Ryan
Old Sep 26, 2004 | 05:02 PM
civicdust's Avatar
anyone know who sells already made harnesssssss, or someone who will do it for cheap? i need the car asap..(Daily driver)
Old Sep 26, 2004 | 05:08 PM
davens's Avatar
http://hasport.com/Products/Wiring.htm
jeez...
Old Sep 26, 2004 | 05:14 PM
civicdust's Avatar
Default Re: (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">http://hasport.com/Products/Wiring.htm
jeez...</TD></TR></TABLE>
&lt;3
anyways, after reading this https://honda-tech.com/zerothread?id=650219
it came down to the conclusion that i have a dx, and i was misinformed by the stupid ex owner of the car. Sorry guys, its time to get messy
Old Sep 26, 2004 | 06:08 PM
Rywire's Avatar
Default Re: (civicdust)
I make those haenesses as well, and they are only $55 shipped.
Ryan
Old Sep 26, 2004 | 08:36 PM
jedubz's Avatar
I still dont know how people can not know that they own a DX. ******* DUAL POINT FUEL INJECTION IS SO ******* OVBVIOS
Old Sep 27, 2004 | 08:57 AM
NCchris's Avatar
Default Re: (jedubz)
You might also wanna read: https://honda-tech.com/zerothread?id=982646
HTH
chris
Old Sep 27, 2004 | 10:47 AM
Cornwhiskey's Avatar
I would use the hf harness i have a 88 hf and it was a 8 valve motor and i had a si harness to use the car wouldnt start wouldnt do anything... im runnin lsvtec with a hf harness with no problems.
Old Sep 27, 2004 | 10:26 PM
civicdust's Avatar
Default Re: couple of ?'s 91 crx hf -swap (sparvar)
alright guys i am almost done with my MPFI swap, but i have a question.
i wired everything up, except for injector 1 i think (brown wire) im suppost to connect it to a yellow injector wire my old motor had...but which one? is it the one on the green plug? because i used the (yellow/black) wire from that plug to connect it to the resistor. let me know
also, anyone have pics of a j1 tranny? i wanna see how the fork looks so i can buy it.
and i still need to know how to wire the hoses for the manifold
CD
Old Sep 27, 2004 | 11:12 PM
civicdust's Avatar
one more thing. do i use this for my ecu
http://www.zcspeed.com/wiring.htm
or this one
http://www.customcivics.com/~b...e.htm
(scroll down)
Old Sep 28, 2004 | 12:06 AM
civicdust's Avatar
GREEN -theres holes here. so screws go in there or is it open like that?
YELLOW - what goes there?
RED - and this is known as?
ORANGE - where does it connect it to?
Old Sep 28, 2004 | 09:55 AM
Rywire's Avatar
Red- dashpot???? Controls the fall of revs between shifts. That hose goes to the stock intake arm.
yellow- Thats the 88-91/92 civic/crx sir manifold, so nothing goes there. There is something there on the integra version.
green- the right side a brake booster hose goes into. The left side is your iacv(correct if wrong) and a coolant hose from the back of the block plugs into the bottom.
orange- thats the pcv, it continues down into the "black box" on the back of the block.
Hope I helped a little. Ryan
Old Sep 28, 2004 | 09:57 AM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdust &raquo;</TD></TR><TR><TD CLASS="quote">one more thing. do i use this for my ecu
or this one
(scroll down)</TD></TR></TABLE>
Use the top link for the mpfi swap, and the bottom for the engine swap. Or this link for the engine swap!!! http://www.geocities.com/dropp...p.htm
KDvtec5757
Jun 24, 2009 07:44 PM
Rene M
Mar 19, 2006 01:11 PM
crxb18a1
24
Aug 14, 2004 05:39 PM
mobrep
12
Jun 15, 2002 05:10 PM
mobrep
Jun 14, 2002 04:30 PM
