cheap and good mods
Old Dec 11, 2001 | 08:19 PM
VtecB17A's Avatar
Default cheap and good mods
i got a 1992 gsr...wit just intake and exhaust and i ran a 16 flat, what are some good mods under 200$?
Old Dec 12, 2001 | 06:20 AM
Spade's Avatar
Default Re: cheap and good mods (VtecB17A)
free flowing cat.........that's it.
Old Dec 12, 2001 | 09:54 AM
Screamer's Avatar
Buy a Drenol and port and polish the TB without tuching the part where the butterfly is. Change your plugs, thermostat, oil pickup pump, timing belt, break fluid, flush your cooling system, due a valve adjustment, flush your tranny fluid (if it is hydraulic). There is tons of things you can do to make your car perform better, all you need is time, lots of it.
Old Dec 12, 2001 | 10:00 AM
Scary1109's Avatar
Default Re: cheap and good mods (Screamer)
did you do that TB polishing yourself? and do you have any pics
Old Dec 12, 2001 | 11:19 AM
Tweakmeister's Avatar
Default Re: cheap and good mods (Scary1109)
Tighten throttle cable (not too tight though, leave it a little loose...you'll see what I mean).
And advance timing.
Both are relatively...free.
Old Dec 12, 2001 | 12:23 PM
Grimm's Avatar
Default Re: cheap and good mods (Tweakmeister)
advanced timing what is that... polishing and everything posted by screamer... what does that all intale , i've flushed the radiator and got new fluids. what about better spark plugs,
Old Dec 12, 2001 | 01:10 PM
Sonic's Avatar
Default Re: cheap and good mods (Grimm)
Good suggestions above, and I'll reiterate some:
Make sure throttle cable is in spec, adjust valves to the tightest gap in factory spec or even .001 tighter, Advance timing to 18, make sure you have good spark plugs etc, get a used cold air intake. It's tough to do much with $200. Just keep driving and you should get faster even with no mods to the car.
Old Dec 12, 2001 | 08:53 PM
93LSivic's Avatar
If you advance your ignition make sure you dont use anything less than the highest octane available or you will detonate. Dont mess with the throttle cable, that is so stupid, just take off the intake hose and have a friend depress your gas pedal fully and make sure the throttle plate is opening fully--if not this is when you adjust the cable. If you have ac, take the belt off, its winter you dont need it--good for a couple hp. Lighten the car up, get AAA and lose the spare and jack and sub box--bass doesnt do anything but make you tone deaf (in certain instances this can be bad--if your cars making weird noises you wont hear them dummy ) Umm, what else. Proper tire inflation, oil level in motor and trans, fresh antifreeze. Cant think of anything else. Oh and if you have the ***** do this
Old Dec 12, 2001 | 10:14 PM
ALLMOTORKING's Avatar
weight reduction=FREE
unbolt exhaust from header b4 racing=FREE
get rid of the big rims if u have em
Old Dec 13, 2001 | 12:12 AM
speedymon's Avatar
Default Re: cheap and good mods (ALLMOTORKING)
Are you serious? No need for backpressure?
Old Dec 13, 2001 | 12:26 AM
screw backpressure, a few runs with this and u may not wanna hook it back up...but u will go def and get tickets for noisyness
Old Dec 13, 2001 | 04:56 AM
meanteg's Avatar
New User
backpressure is good for street where you need torque, but for the 1/4 you want more horsepower!
Old Dec 13, 2001 | 06:25 AM
freud's Avatar
Default Re: cheap and good mods (meanteg)
ummm.... horsepower is derived from torque.
Old Dec 13, 2001 | 06:31 AM
Kalokohan's Avatar
New User
Default Re: cheap and good mods (93LSivic)
Damn open header, I mean no header!! Woudn't that make you deaf as well as the bass?
Old Dec 13, 2001 | 09:35 AM
Brian's Avatar
Default Re: cheap and good mods (Guardson3r3)
I think he meant the port/polish job. You would melt your front bumper and everything else if you fired the car with no header on there.
Old Dec 13, 2001 | 09:46 AM
Default Re: cheap and good mods (Spade)
yo, are u guys new,,i didnt say take the header off....i said unbolt your exhaust from the header.hence open header...cmon people i know u were joking anyway right????
Old Dec 13, 2001 | 01:15 PM
brian b's Avatar
New User
my car runs a straight downpipe.. its quiet enough to drive past a cop at 3000 rpm in texas.. turbo works wonders
Old Dec 13, 2001 | 08:26 PM
meanteg's Avatar
New User
Default Re: cheap and good mods (brian b)
I know.... ok, You need some backpressure to get more torque for driveability.
BUT if you unplug the exhaust, you get a little more top end, but you lose some low end torque!
better?
Old Dec 15, 2001 | 12:41 PM
iwhichisme's Avatar
i think he ment to port the opening to the eshaust manifold
Old Dec 15, 2001 | 06:25 PM
Speed_Ricer99's Avatar
That makes no sence at all.
keep the exhaust on
Old Dec 15, 2001 | 06:44 PM
nfn15037's Avatar
Default Re: cheap and good mods (Speed_Ricer99)
A 16?!? Doesnt that have a B17 in it? As in 160 HP, yeah well my boys Saturn runs 16s, so i think you need to work on driving technique a little before you start modding your ride. Practice is key.
Old Dec 15, 2001 | 09:58 PM
Smashback's Avatar
That's why all the fast race cars run exhaust ... er, wait a minute, no they don't. I guess they run no exhaust because it makes them slower. They probably just don't want to go too fast.
Old Dec 16, 2001 | 06:37 AM
Westrock2000's Avatar
When visiting Mount Honda, be sure to explore the ancient caves of the Headerona Tribe and see the beautifull snow covered cliffs.
Old Dec 16, 2001 | 01:59 PM
93LSivic's Avatar
Default Re: cheap and good mods (Westrock2000)
Hehe, rollin my *** off!! Dont eat yellow, err silver snow......
supergtp1
Jun 2, 2014 10:22 PM
gnnr2
Apr 30, 2012 01:33 PM
DC2_ITR
Apr 26, 2007 07:52 PM
dylokjai
Mar 24, 2005 11:02 AM
who00knows
Jul 31, 2003 05:39 AM
