Car shakes?
Whenever I first take off, my car starts to shake and rattle. It only happens when i first take off. After that, it goes away. Anybody know what it is? This is on an 88 crx hf.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">from where what kind shake the motor the car itself seats elbotrate plz</TD></TR></TABLE>
It's coming from the engine compartment. It's not the actual car itself.
From: I told you to wait in the truck in Texas, United States
The engine "shaking" is usually a result of a "dead miss.."
Which is one particular cylinder not firing/producing power..
{Might be time for a tune-up...}
Does it have a noticable lack of power when this occurs?
Harsh clutch engagement as a result of a worn-out clutch could also cause
a shaking sensation..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackrex »</TD></TR><TR><TD CLASS="quote">Are you sure you're giving it enough gas when you're taking off? Lol. </TD></TR></TABLE>
lol, yes I am giving it enough gas, but that is the kind of shaking it feels like.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">The engine "shaking" is usually a result of a "dead miss.."
I did the tune up, replaced the clutch, and it still happens. No loss of power at all as the shaking only occurs when I first take off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98GeeYes-Are »</TD></TR><TR><TD CLASS="quote">
I did the tune up, replaced the clutch, and it still happens. No loss of power at all as the shaking only occurs when I first take off. </TD></TR></TABLE>
Could be a bad dif or struts. I couldn't tell you for sure without riding in it.
check your motor mounts the rubber might be cracking it might not be demolished but even if its wore out in the middle around the metal spacer in the rubber could make it shake at a lower rpm ....or could be the flywheel like he said...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">Did you have the flywheel surfaced when you replaced your clutch?</TD></TR></TABLE>
Yes, I had the flywheel resurfaced. I will check the motor mounts.
i know my car vibrates a lot but it is from the Hasport Mounts. they are really stiff. i like it though
like they said, check the motor mounts. you might need to retorque one of them or maybe replace an insert or something.
check your brakes make sure the cylinders arent seizing and makin your rotors worp......when they seize they wont let the cylinder go back until its forced back.hope ya find the problem
