timing question
Old Sep 24, 2004 | 12:24 PM
Origin's Avatar
Default timing question
going to finally time my car, everything i read says i need to jump the service connector. c-speed racing says its under the dash, but is it on the drivers side fender (the little yellow plug that is capped off?). this is a b16a obd1 88 crx hf.
Old Sep 25, 2004 | 10:13 AM
Origin's Avatar
Default Re: timing question (Origin)
Old Sep 25, 2004 | 10:42 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
On the earier models it was under the hood:
Old Sep 25, 2004 | 10:54 AM
Origin's Avatar
Default Re: timing question (88DXCRX)
thanks man, i thought that was it.
Old Sep 25, 2004 | 12:46 PM
xbB's Avatar
xbB
What exactly does it do? What if You don't use it?
Old Sep 25, 2004 | 01:18 PM
88DXCRX's Avatar
Default Re: timing question (CRXcellent)
It lets the ECU know that the base ignition timing is being set
so that when you rotate the distributor with the engine running
to advance or retard,The ECU does not attempt to alter it ..
Old Sep 25, 2004 | 02:27 PM
tRex99's Avatar
HWOA i never heard of this...i mean i know the dizzy part how you advance or retard but what i just picked up by your post was that if i just do it to the dizzy without messing with that yellow piece then the ecu corrects it anyway?? so i wont retard or advance at all? I want to advance it a little bit to kick off a litttle better top end i have a 91 crx si so what all do i need to do to advance the timing beside the moving of the distributor???? and i shouldnt go to far right?
Old Sep 25, 2004 | 02:31 PM
DocSean's Avatar
Default Re: timing question (tRex99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRex99 &raquo;</TD></TR><TR><TD CLASS="quote"> HWOA i never heard of this...i mean i know the dizzy part how you advance or retard but what i just picked up by your post was that if i just do it to the dizzy without messing with that yellow piece then the ecu corrects it anyway?? so i wont retard or advance at all? I want to advance it a little bit to kick off a litttle better top end i have a 91 crx si so what all do i need to do to advance the timing beside the moving of the distributor???? and i shouldnt go to far right?</TD></TR></TABLE>
Yeah...whats up?
Old Sep 28, 2004 | 05:15 PM
88DXCRX's Avatar
If you are just playing with the timing,You don't have to jumper it..
If you are setting the base ignition timing to factory specs,
I.E.&gt;Using a timing light,that is when you jumper it..
JohnnyEF
Feb 10, 2010 06:09 PM
---SPEED-DEMON---
Engine Management and Tuning
Apr 1, 2009 12:14 AM
godruler
Feb 25, 2006 07:47 PM
wilsel
Mar 23, 2005 05:37 PM
tilt
Aug 13, 2003 12:01 PM
