CEL, Cant check it, whats wrong?
Old Sep 24, 2004 | 12:42 AM
beeroh's Avatar
Default CEL, Cant check it, whats wrong?
Ive searched and found out how to check the CEL codes but I can't get mine to work. I went as far as cutting the blue connector off and splicing the wires to make sure they were getting contact with each other. Still nothing. My CEL only comes on when im driving and shuts off when I turn her off. Then it doesn't come back on till im driving again. Ive tried to check the CEL whille the engine was running but all it does is give the engine a slight hesitation then it goes on its business and the CEL is still on with no flashes or blinks. I tried the conventional way of connecting the wires and turning the ignition to the on position and still no signal. Im lost and don't know what to do.
someone please help, I need to fix this problem,
my computer in the car is an OBD0 PO8 if that helps anyone.
Old Sep 24, 2004 | 12:53 AM
smart monkey's Avatar
Default Re: CEL, Cant check it, whats wrong? (beeroh)
have you tried reading the codes at the ecu?
Krakkles's Avatar
Are you thinking the CEL itself will blink the code?
You have to pull the carpet in the passenger footwell up and look at the LED on the ECU. (speaking from my 91 Si experience, I believe some years had it under the passenger seat as well)
Also, mine does it without jumping the blue connector.
Old Sep 24, 2004 | 01:04 AM
beeroh's Avatar
Default Re: CEL, Cant check it, whats wrong? (Krakkles)
I thought the CEL was supposed to blink the codes. Thats what Ive been reading for the last two days.
Old Sep 24, 2004 | 01:10 AM
Krakkles's Avatar
Nope. Check the LED on the ECU. If I recall correctly, the next chassis (EG/92-95) was the first one with the codes coming out the CEL.
Also, I don't know if you've got some weird procedure for getting the codes (usually key on, key off, key on, key off, key on, or something like that), but you don't need to do that, either. Just get a view of the LED and turn the key on.
Old Sep 24, 2004 | 01:27 AM
beeroh's Avatar
i'll give it a shot tomorrow, thanks everyone
Old Sep 24, 2004 | 06:08 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beeroh &raquo;</TD></TR><TR><TD CLASS="quote">
my computer in the car is an OBD0 PO8 if that helps anyone.</TD></TR></TABLE>
P08 : 92-95 OBD-1 Civic D15 JDM
check again
Old Sep 24, 2004 | 08:16 AM
DieMaster's Avatar
Needs to be About 20% Cooler
yea on a ob0 car the blue conecter under the passenger dash is ur ingition timing ajusting plug. the computer cant change the timimng with this plug shorted and u can ajust timing.
ur codes blink an a led on the ecu
an EG is an obd1 and u short out the plug to read the codes on ur CEL. if it wont
check the pin at the ecu but i dint know wich one
kyang03
Mar 6, 2014 07:31 PM
91ef_civic
Mar 22, 2011 02:33 PM
LSpimpTEC
Jul 29, 2004 09:09 PM
Pfieff
Aug 31, 2003 05:23 PM
MeanGreenEG9
Dec 4, 2002 07:58 AM
