What is your Oil Pressure
Old Sep 23, 2004 | 08:00 PM
ares650's Avatar
Default What is your Oil Pressure
How much oil pressure do you guys see on your H22?
In warm idle?
WOT?
Where do you have your gauge conneted?
And are you boosting?
Thanks
Old Sep 29, 2004 | 05:21 PM
ares650's Avatar
Default Re: What is your Oil Pressure (ares650)
bump!
Old Sep 29, 2004 | 08:47 PM
01 LudeDude's Avatar
warm idle - ~20psi
wot - 80psi
Guage connected at sender
JRSC @ 6psi
Old Sep 30, 2004 | 05:06 AM
ares650's Avatar
Default Re: What is your Oil Pressure (01 LudeDude)
what oil are you runing?
do you ever see it go down to 10 or 15 psi?
Old Sep 30, 2004 | 07:37 AM
577HondaPrelude's Avatar
10 to 15 is ok, when at idel. As long as you have 50+ PSI when you are driving (3K RPM or more).
Here are some nubers I took of oil pressure a while ago.
Oil temp was at 210, and I'm using Amsiol 5w30.
RPM - Oil Pressure
700 - 25
1500 - 37
2500 - 50
3000 - 63
3500 - 75
4000 - 75
5000 - 75
6000 - 75
7000 - 75
7400 - 75
Old Sep 30, 2004 | 07:51 AM
kb58's Avatar
Banned
Default Re: What is your Oil Pressure (577HondaPrelude)
There' a rule-of-thumb that an engine should see at least 10lb oil pressure for every 1000 engine rpm.
Old Sep 30, 2004 | 08:08 AM
ares650's Avatar
Default Re: What is your Oil Pressure (kb58)
yea, I heard that same rule....... I am using 5/30 and I have since almost 10psi but over 3k I do see 80psi.
Thanks Guys.
Old Oct 1, 2004 | 10:38 PM
flashmang's Avatar
i just installed my gauges ...
i usually sit at 10-15 psi warm and can see up to 80 when driving
10w/30 Royal Purple
Old Oct 2, 2004 | 07:18 AM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ares650 &raquo;</TD></TR><TR><TD CLASS="quote">yea, I heard that same rule....... I am using 5/30 and I have since almost 10psi but over 3k I do see 80psi.
Thanks Guys.</TD></TR></TABLE>
i used to use 5/30..then i got my helms and it says 10/30 so i use that...one time(in band camp) i was low and i only had 10/40...it raised my pressure since it was thicker..might want to use 10/30...i get worried when its below 18 or so
Old Oct 2, 2004 | 03:30 PM
ares650's Avatar
Default Re: What is your Oil Pressure (fastludeh22)
cool, Thanks for the info....
Old Oct 2, 2004 | 04:13 PM
kentuckyprelude's Avatar
I run 20psi on start up. and 75psi on the gas
ProjectBB6
Sep 16, 2009 02:18 PM
Rob97'SH
Feb 9, 2009 10:55 AM
vladd
Apr 9, 2007 02:24 PM
platinum00
May 14, 2006 06:40 AM
USDM 4G VTEC
Sep 3, 2003 08:26 PM
