ITR or CTR cams?
Old Sep 23, 2004 | 05:06 PM
de_sxc_b20_teg's Avatar
Default ITR or CTR cams?
What cams should I use on a B20B. I'm considering JDM ITR's or CTR, if they fit that is! Any suggestions about the pro's and con's to either one?
Old Sep 23, 2004 | 05:11 PM
MaskedAP1's Avatar
Default Re: ITR or CTR cams? (de_sxc_b20_teg)
vtec cams wont fit in nonvtec y0!
Old Sep 23, 2004 | 07:20 PM
gearkraft's Avatar
the stock b20 head is non-vtec. those cams would be worthless. on the other hand if you were trying to go CRvtec (b20 bottom end with vtec head) then your best choice would be the CTR cams, why? well because the civic type R cams have a slightly more aggressive intake cam lobe then its integra type R brother. The exhaust cam between the two however, are exactly the same. hope this helped.
Old Sep 23, 2004 | 08:11 PM
VTECorona's Avatar
Default Re: (gearkraft)
I'm pretty sure the 00-01 ITR cams are the same as CTR. If not they are negligibly close.
Old Sep 23, 2004 | 09:42 PM
Slain's Avatar
i honestly dont think you can tell the difference between itr or ctr cams gains wise <shrugs>
Old Sep 24, 2004 | 12:30 AM
XtremeCarTuner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by de_sxc_b20_teg &raquo;</TD></TR><TR><TD CLASS="quote">What cams should I use on a B20B. I'm considering JDM ITR's or CTR, if they fit that is! Any suggestions about the pro's and con's to either one? </TD></TR></TABLE>
omg.....
dude.. the B20B motor has a non-vtec head but if considering a CRVtec, any of those cams you listed will do.
Old Sep 24, 2004 | 06:27 AM
Default Re: ITR or CTR cams? (XtremeCarTuner)
I was gonna go with a GSR head, but I still haven't decided! I may just stay non-boost! If I do stay non-vtec then I still need some cams!
Old Sep 24, 2004 | 06:40 AM
dFreezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearkraft &raquo;</TD></TR><TR><TD CLASS="quote">the stock b20 head is non-vtec. those cams would be worthless. on the other hand if you were trying to go CRvtec (b20 bottom end with vtec head) then your best choice would be the CTR cams, why? well because the civic type R cams have a slightly more aggressive intake cam lobe then its integra type R brother. The exhaust cam between the two however, are exactly the same. hope this helped.</TD></TR></TABLE>
the 00-01 ITR cams are identical to the CTRs
EJ8 GSR-T
Feb 20, 2006 09:42 PM
rev2ninetyper
Jul 21, 2004 04:08 AM
kenepo_vtec
Jul 4, 2004 08:57 PM
498GSR
Oct 28, 2002 10:06 PM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
