Injector keeps getting stuck open!
Hey guys so i have a boosted b18c and it was running good got it tuned and everything and then my fuel line from filter to fuel rail started leaking so i ordered new filter and line and fittings and got that installed and then turned car on let it idle turned it off for like two days and when i tried to start it again it just made a clunk noise like it was locked up and i thought it was the starter but it wasnt so i removed spark plugs and cylinder 1 and 2 were full of fuel. i removed them and drained fuel from cylinder and cleaned them and put them back and now only cyl 2 injector did it again it filled cylinder with fuel so i took them out hooked them up individually to a battery and cleaned them with carb cleaner and i also let them sit submerged in carb cleaner for a few hours went to put them back and it idled good for about 3 mins and then turned off and i removed spark plugs and cylinder 2 flooded again. and i removed the injector and i can blow air through it again before i installed it the last time i tested it make sure it closed and opened multiple times, so could it be its just bad or is there still gunk inside keeping it stuck open? Thanks!
Re: Injector keeps getting stuck open!
It is hard to tell... what kind of fuel injectors are they ??? Can you substitute another set to rule out a problem with the ECU and wiring ??? What about a resistor box... are you using one of them for the injectors that you have ???
No resistor box they are Bosch 1000cc and it stays open even when I take it off the motor and I’ll tap on it or clean it and sometimes it works when I put power to it to open it but then after couple times it’ll stop clicking and it stays open cause I can blow air through it
I’m running e85 but here it’s not true e85 it’s e54 and they were just cleaned and flow tested before the tune a few weeks ago but maybe the fuel filter was just full of gunk and it got in the injectors? Don’t know when it was last replaced but I just replaced it this week
rice a roni
Engine Management and Tuning
10-15-2015 05:11 AM
davidbrookstone
11-11-2011 11:38 AM
