What intake manifold is this?
Re: What intake manifold is this?
When doing my Mini-Me I remember someone saying some B-series intakes and TB's will fit certain D-Series heads. I just don't remember which one's because I already got a Skunk2 Intake and TB on my build. tossed it in the useless info file and brain dumped it
wrong. no b series manifolds will fit a d series head........ OP first off find out what head is on your block. if its a b16 head then it can fit the b16 intake mani or a b18c5 "type r" . skunk 2 manifolds, blox and oem type r all looked like this. if its an oem manifold then there should be a Pxx stamp on the back of it
Could it be a modified LS intake? I know a b16 manifold can be modded to fit an LS but not sure of it goes the other way.
My guess is a first generation Skunk2 or Blox I/M. If it was an OE intake manifold, as stated above, you would see a PXX cast into the rear face on the driver's side (opposite end from the throttle body mounting flange). The only OE intake manifolds that are smooth on top like yours is would be a B18B (P74/P75) or an ITR (P73) just for reference.
The itr doesn't have that twist on the plenum. It also has only one nipple in the front side where this one has two . It's not a b16 manifold. The early skunkworks manifolds were just re boxed itr manifolds . That's a wtf manifold. The homemade throttle cable bracket is pretty neat. Lol.
It looks like an LS manifold with the placement of the lines for the black box and FPR. There is also a tab for the PCV purge, which makes it look more like the OEM LS intake. Is there a vacuum nipple on the back right under the purge solenoid tab? If it is an OEM intake (and hasn't been shaved) that's where your stamped code will be.
civic89si666
12-26-2007 07:21 PM
