What intake manifold is this?
Old 04-15-2019, 02:17 AM
Mixedb16's Avatar
Default What intake manifold is this?
Need help identifying this intake manifold, engine is a b16a (obd2) thanks guys.
Old 04-15-2019, 06:33 AM
Krauthammer's Avatar
Default Re: What intake manifold is this?
I'm probably wrong, but it kinda looks like a D-series intake...
Old 04-15-2019, 08:15 AM
Mixedb16's Avatar
I mean would that even bolt up??? Haha.
Old 04-15-2019, 08:47 AM
When doing my Mini-Me I remember someone saying some B-series intakes and TB's will fit certain D-Series heads. I just don't remember which one's because I already got a Skunk2 Intake and TB on my build. tossed it in the useless info file and brain dumped it
Old 04-15-2019, 08:16 PM
chingpo05's Avatar
wrong. no b series manifolds will fit a d series head........ OP first off find out what head is on your block. if its a b16 head then it can fit the b16 intake mani or a b18c5 "type r" . skunk 2 manifolds, blox and oem type r all looked like this. if its an oem manifold then there should be a Pxx stamp on the back of it
Old 04-18-2019, 08:37 AM
Mixedb16's Avatar
its a pr3 head I’ll have to look for a stamp when I get home from work today.
Old 04-18-2019, 11:40 AM
punk0mi's Avatar
It looks like a PR3/B16A intake manifold...painted black tho.
It is way too small for a ITR.
Old 04-18-2019, 11:53 AM
BiggieBert's Avatar
Could it be a modified LS intake? I know a b16 manifold can be modded to fit an LS but not sure of it goes the other way.
Old 04-18-2019, 12:21 PM
Full_Tilt's Avatar
Looks like an LS (B18B) manifold.
Old 04-18-2019, 09:03 PM
JRCivic1's Avatar
My guess is a first generation Skunk2 or Blox I/M. If it was an OE intake manifold, as stated above, you would see a PXX cast into the rear face on the driver's side (opposite end from the throttle body mounting flange). The only OE intake manifolds that are smooth on top like yours is would be a B18B (P74/P75) or an ITR (P73) just for reference.
Old 04-20-2019, 08:36 AM
linkdeezie's Avatar
It's either a ITR or a Gen1 Skunk2...
Old 04-20-2019, 11:13 AM
stin1's Avatar
The itr doesn't have that twist on the plenum. It also has only one nipple in the front side where this one has two . It's not a b16 manifold. The early skunkworks manifolds were just re boxed itr manifolds . That's a wtf manifold. The homemade throttle cable bracket is pretty neat. Lol.
Old 04-21-2019, 12:34 AM
Crashmaster91's Avatar
It looks like an LS manifold with the placement of the lines for the black box and FPR. There is also a tab for the PCV purge, which makes it look more like the OEM LS intake. Is there a vacuum nipple on the back right under the purge solenoid tab? If it is an OEM intake (and hasn't been shaved) that's where your stamped code will be.
dragula
11-03-2011 04:51 PM
civic89si666
12-26-2007 07:21 PM
p1ccoloz
03-07-2003 01:09 AM
Quick Reply: What intake manifold is this?
