Forged All Motor Pistons on Turbo Car?
Old 02-15-2019, 10:41 AM
Low Ek's Avatar
Default Forged All Motor Pistons on Turbo Car?
Hey guys I tried to do some searching but couldn’t really find anything. I was wondering if there’s any downside to using a “All Motor” forged Piston in an engine your building for boost?
The pistons are from Arias. From what I can tell the Turbo pistons and All motor pistons are made out of the same material and weigh almost identical. The compression ratio is in the 9.0:1 so it’s not high.
Old 02-15-2019, 11:36 AM
turboLScrx's Avatar
Default Re: Forged All Motor Pistons on Turbo Car?
from everything I’ve learned the all motor pistons and rods are light weight but they are not as strong and would be limited compared to a normal H beam or I beam rod or piston designed for turbo application
Old 02-15-2019, 02:57 PM
O.G. triple O.G.
NVturbo's Avatar
Just get the correct type of pistons for your application. It's not fun nor cost-effective replacing them when you could have got the specified ones to begin with.
Old 02-15-2019, 09:35 PM
JKaze's Avatar
Well, it is also depending factors like target boost and power level. Cylinder maximal working pressure load. Whole setup overall.
Generally, of course there is differs in base desing between ”all motor”- and ”turbo” pistons (like pin area, skirt width, dome thickness and pistonring placement), but it does not mean that n/a-piston can not survive in forced induction condiotions.
Old 02-16-2019, 01:31 PM
Premium Member
Aradin's Avatar
The included pins are different. Arias includes thin wall pins with their NA pistons that will not tolerate high boost/torque levels. You will at least need to get pins designed for a forced induction application.
Old 02-17-2019, 05:22 AM
Moderator
TheShodan's Avatar
that's like that with all the companies. You can buy their thicker walled pins separately.
Old 02-17-2019, 06:55 AM
Low Ek's Avatar
Thanks for all the replies guys. I always wondered if it truly did make a difference. I honestly thought it was all just C.R and design differences.
Sleeperzzz95
Northeast (Sales)
01-26-2011 08:25 PM
gsr95
02-06-2008 12:40 PM
Spectrum24x
03-09-2006 07:14 AM
GusRock77
Honda S2000
16
03-01-2005 12:24 PM
civictom
11-20-2001 07:47 PM
Quick Reply: Forged All Motor Pistons on Turbo Car?
