Del sol dash lights not turning on
Old 07-18-2018, 10:46 PM
Elijah Trevino's Avatar
Default Del sol dash lights not turning on
My 95 del sol gauge cluster lights won't turn on. I've checked the fuse and it's still good. Can someone help
Old 07-19-2018, 05:08 AM
mk378's Avatar
Default Re: Del sol dash lights not turning on
It is not inconceivable that every single dash illumination bulb is burnt out, especially if a previous owner drove all the time with them fully bright.
Check that the tail lights and front corner lights work. They're on the same circuit and fuse. Then I'd go to the bulbs.
Sometimes the dimmer control is bad. This can be checked by substitution or by jumping the solid red wire on the back of the control to the solid black one. The dash lights should then come on fully bright when the light switch is turned on.
Old 07-19-2018, 07:02 AM
Not too long ago I had switched o u to most of the bulbs for LEDs
Phrog
19
02-02-2014 07:37 AM
mike11
18
07-21-2011 07:22 PM
TwoKSiR
05-19-2009 10:13 AM
dc2rboost
11
05-26-2005 03:21 PM
94_del_sol
08-29-2004 07:54 PM
Quick Reply: Del sol dash lights not turning on
