help... no dash lights on my sol
Old 05-21-2005, 04:37 PM
dc2rboost's Avatar
Default help... no dash lights on my sol
umm i have nothin.. no lights, only thing that works is the clock and it gets dimmer when i run the lights on wtf.. o yeah and the heater control unit doesnt light up eather.. i thinking its the dimmer switch.. in the cluster itself. but can the be replaced? anyway other ideas on geting my stuff lighted up..lol thanks for your time!
Old 05-21-2005, 04:45 PM
Stoich EG2's Avatar
Default Re: help... no dash lights on my sol (westcoastRICE)
did you check your fuses buddy? and uhhh, your clock is supposed to get dimmer when you turn on your headlights... because if you turn on the headlights, it's supposed to be DARK outside therefore you wouldnt notice the clock being very dim.
Old 05-21-2005, 11:11 PM
dc2rboost's Avatar
witch fuse.. all over them ok under the dash... i got confused when i looked at the pannel its like saying theres 3 rows of fuses and theres only 2...
Old 05-22-2005, 07:53 AM
importnoodles's Avatar
Default Re: (westcoastRICE)
Once upon a time, i was fixing my friends stereo in his car, while he was driving. All of a sudden, POOF! All the interior lights went off. The end.
I blew a bunch of fuses. It's the fuses man.
Old 05-22-2005, 08:47 AM
postman's Avatar
i dont even think its the fuses, you probably need to adjust your dimmer switch
Old 05-22-2005, 08:50 AM
nocturnaldragon's Avatar
Fuse #40 40amp Light Fuse (underhood)
Fuse #19 10amp Taillight, InstrumentLigh, License light (underdash)
Fuse #03 7.5amp Interior Light (underdash)
That should be all the ones that affect the lights on the dash.
Old 05-22-2005, 10:04 AM
dc2rboost's Avatar
adjust it?? it doent work!
Old 05-22-2005, 10:12 AM
dc2rboost's Avatar
ok ill check them
Old 05-22-2005, 11:30 AM
SOHCejcivic's Avatar
i had a bad combo switch when my dash lights wouldn't come on. i had no dash lights, no front corners, no rear tails/liscense plate lights.
Old 05-22-2005, 12:19 PM
idriveadelsol7's Avatar
maybe you're leds behind the thing are just hold and need to be replaced... when i buoght my del sol (94) some parts on the gauge cluster don't light up.
Old 05-22-2005, 12:48 PM
dc2rboost's Avatar
everything else works.. but the lights in my dash and the lights for the heatercontrol dont work.
Old 05-26-2005, 03:21 PM
dc2rboost's Avatar
found out that the dimmer switch in the cluster was toast! thanks for your help guys
billdozer79
09-12-2017 01:25 PM
2.2accord
06-09-2011 07:50 AM
BLU CIVIC
12-29-2010 03:31 AM
white ef
10-11-2008 08:33 PM
1431TypeR
01-21-2003 06:01 PM
Quick Reply: help... no dash lights on my sol
