Changing timing belt... What other maintenance should I do while I'm down there?
Old 07-17-2018, 02:47 PM
crz650's Avatar
Default Changing timing belt 93 civic.. What other maintenance to do while I'm down there?
Doing a timing belt job soon. I'm at 150,000. Is there anything else I should do or check out since I'm removing the valve cover? Oil seals or anything?
1993 Honda Civic VX Hatchback D15Z1 1.5L
Old 07-17-2018, 02:51 PM
Hysterically Calm
TomCat39's Avatar
Default Re: Changing timing belt... What other maintenance should I do while I'm down there?
What vehicle?
Old 07-17-2018, 03:19 PM
crz650's Avatar
Originally Posted by TomCat39
What vehicle?
Ohh sorry it's a 1993 Honda Civic VX Hatchback D15Z1
Old 07-17-2018, 10:39 PM
Fish Twig
tony_2018's Avatar
everything behind the tming belt cover
Old 07-18-2018, 03:23 AM
O.G. triple O.G.
NVturbo's Avatar
timing belt
water pump
front main seal (oil pump seal)
accessory belts
thermostat
cam seal
valve cover gasket
spark plug oil seals
spark plugs
Old 07-18-2018, 12:45 PM
Hysterically Calm
TomCat39's Avatar
Originally Posted by NVturbo
timing belt
water pump
accessory belts
thermostat
cam seal
valve cover gasket
spark plugs
Why no front main crank seal?
The reason I asked what vehicle, some have oil coolers and some do not behind the oil filter.
Also want to check to see if this thread belongs in this forum.
Old 07-18-2018, 01:30 PM
EL Vap133's Avatar
Might as well replace the tensioner too....
Old 07-18-2018, 02:53 PM
Fish Twig
tony_2018's Avatar
ban his ***!!!!
Old 07-19-2018, 02:20 AM
O.G. triple O.G.
NVturbo's Avatar
I believe I included that...
Old 07-19-2018, 07:24 AM
Kevs02Accord's Avatar
timing belt
water pump
accessory belts
thermostat
cam seal
valve cover gasket
spark plugs
nailed it. also, dont buy cheap **** parts or you will be back into again, unless you dont plan on keeping the car for long.
Old 07-19-2018, 09:59 AM
crz650's Avatar
awesome thank you guys so much i just ordered some more parts.
couple more questions.
Which coolant should I use?
I'm also looking for rear trailing arm bushings but cant find them on oem part sites. what should company should i replace it with? looking for close to oem
Old 07-19-2018, 11:00 AM
Hysterically Calm
TomCat39's Avatar
I'm blind.
Are you in the USA, Canada, some other country? I ask as some fluids available to me in Canada may not be available to people in USA and vice versa (ask me how I know. )
Old 07-19-2018, 03:03 PM
Freedo_Civegra's Avatar
Use OEM coolant from the dealer. I didn’t but am going to due to Tony’s recommendation.
Old 07-19-2018, 03:17 PM
Hysterically Calm
TomCat39's Avatar
In Canada we have a brand called OEM that allegedly is formulated to the same spec as dealer, they provide for each of the major manufacturers. We also have store brands that are for the specific model/type.
I'm not sure if you have the same availability in the states.
http://www.canadiantire.ca/en/pdp/oe...-0293080p.html
http://www.canadiantire.ca/en/pdp/mo...-0293070p.html
Old 07-19-2018, 09:35 PM
crz650's Avatar
I'm blind.
USA, California
Old 07-20-2018, 02:38 AM
O.G. triple O.G.
NVturbo's Avatar
coolant from local auto parts store will be fine. I would stay away from 50/50 type because who's to say the content is actually half coolant and half water. I usually get 100% coolant and get a gallon of distilled water.
Old 07-20-2018, 10:23 AM
Everyone has a thing. I used that mix with any color stuff...
spoondive
10-17-2014 04:01 PM
TOO MUCH TORQUE
04-18-2011 06:27 AM
TeaAddict
11-27-2006 10:12 AM
brinks
12-15-2001 06:20 PM
Quick Reply: Changing timing belt... What other maintenance should I do while I'm down there?
