Bad wheel bearing feels like the brakes are on?
Old 03-15-2018, 06:04 PM
MooreJo02's Avatar
Default Bad wheel bearing feels like the brakes are on?
For the last few weeks I've noticed a humming from the rear driver's side, and assumed it was a wheel bearing (I know it's not a good idea to drive on bad wheel bearings, but money's tight and I had no other choice)
A few minutes ago I got the wheel in the air and when I spun it, it didn't want to spin freely like the brakes weren't fully released. I had an issue in the past where the brakes on that wheel were only wearing down on the inside. The inside pad wore down to the metal and chewed up my rotor, while the outside pad was probably at 80% life.
I fixed it (supposedly) after lubricating and installing new slide pins since the old ones were stuck and didn't want to move.
The other side spun fine, so now I'm thinking the brake problem has come back and it's not a wheel bearing.
Any thoughts?
Old 03-15-2018, 11:17 PM
holmesnmanny's Avatar
Default Re: Bad wheel bearing feels like the brakes are on?
could be the piston seizing, you should be able to tell when you try to pull the caliper off the pads, it will be really tight
Old 03-16-2018, 05:02 AM
MooreJo02's Avatar
Is​​​ the solution to this just new calipers?
Old 03-17-2018, 02:24 AM
it's always possible to rebuild the caliper but ya just replacing the caliper is the trick
psegs80
47
10-20-2010 08:21 AM
mouab18c1
Suspension & Brakes
03-03-2009 08:56 AM
SunkistRex
03-21-2004 08:06 PM
CXHatchback
10-16-2003 04:16 PM
Takeoff
02-23-2003 11:11 AM
Quick Reply: Bad wheel bearing feels like the brakes are on?
