The EBP em1 resurrection.. might be slow
Old 02-04-2018, 03:56 PM
  #26
DSEA2's Avatar
Default Re: The EBP em1 resurrection.. might be slow
Just to settle the debate, in which you were misinformed . The ground on your valve cover is doing absolutely nothing. Unless you mount it to the stud that goes into the head, the valve cover is completely isolated from everything else by the rubber gasket. Even the spot you moved it to is incorrect .
Old 02-09-2018, 06:58 AM
  #27
Darkn3s's Avatar
Hmm very good point. I figured the VC bolts somehow would make contact with the threaded holes in the head but then realize the grommets had rubber too. you win... you win lol
Old 02-27-2018, 07:18 AM
  #28
Darkn3s's Avatar
MOAR updates..
Powder coated the lower IC pipe to match
Silver Artery
installed and clamped
top clamped as well
IC clamped to the turbo
Mac valve added
Precision 44mm added
oil return line actually fit pretty nice
Feed line routed away from the timing belt
feed lined connected
bumper trimmed to fit end tanks
cut the other side to match
might add CF back plates to cover the opening once mounted
test fit
not bad
Old 02-27-2018, 07:26 AM
  #29
Darkn3s's Avatar
decided to pull these fenders off because they were begining to rust towards where it meets the bumper and had a couple of cracks
Test fitted some fresh ones i already had from another civic and decided to keep and mod these before the paint work
the mock up
Used the old fenders as a template to trace them out for the donors
Not bad for my first time
Finished! I guess now i need to paint the rest of the car yellow.. jk
Old 02-27-2018, 07:36 AM
  #30
Darkn3s's Avatar
Picked this CF spark plug cover off Amazon for THE CHEAP.. think it flows good with the purple and black theme
New black valve cover bolt kit coming soon
Another amazon pick up.. $8 for accord replica caps, figured id give it a try
fitment was ok but ended up returning them.. dont look at the shadow
Test fit and mounted the rear lip on the donor bumper
theres a bumper in there somewhere
started taking the body parts apart to drop off at the painters until the car is ready to move #soon
stripped
got no ***
ruined
good by SI badge
parts laid out and ready to drop off
Old 02-27-2018, 08:42 AM
  #31
Ericjergs's Avatar
Nice progress!
Old 03-07-2018, 10:00 AM
  #32
Darkn3s's Avatar
Had to replace the two straight 10AN fittings because it interfered with the IC pipe. A 45degree fitting cleared it perfectly
Both upper bushing needed to be replaced
classic *****/ downpipe pic lol
Old 04-11-2018, 11:39 AM
  #33
Darkn3s's Avatar
Found some like new D2 coils for a good price so decided to pick these up quick and switch out the slammed Tien springs
pretty easy nothing was seized
installed
rears are just as easy
made a quick mounting bracket with rubber spacers to mount the vibrating Macvalve.. looks cleaner too
cleaned up the wiring on this side too while i was here. Yes i will be looming this
e85 prep #fuelfilter
perfect time to switch out the old red 90 fittings
Gauges installed and powered on
Boost gauge pressure sensor installed directly to the manifold
Wideband sensor installed too and easy as hell to get too since these sensors love to fail
Old 04-11-2018, 12:18 PM
  #34
Darkn3s's Avatar
4k idle at start up
Hard to tell from this pic but i have been chasing a high 4k idle problem for a long time and found out what the cause was once we added coolant. It just poured out from under the coolant port. Apparently somehow the intake flange was warped. No worries got my asian friend and a belt sand and went to work.
you can kind of see runner #1 and the coolant port section bowed a little
another view
putting in work
better
Since the manifold was off i thought it would be a good time to try and tuck the wire harness and remove unnecessary wires
all the old loom and sticky old tape is removed
zip tied in place
new layout of the harness before the new loom and heat shrink
removed all the connectors to clean up all the oil/ grease
soaked it in purple power for about 30 minutes
alot better
clean and simple
final product i think shes ready
Since i am no longer going through the factory engine harness for the power wires decided to use a power bulkhead through the firewall for the alternator, starter and fusebox. All this will be hidden under the catch-can any way
bay side view
in car view
power wires attached
power wire from the battery attached
done
Alot better
not bad me.. brake line tuck coming soon
Old 04-12-2018, 08:28 AM
  #35
Ericjergs's Avatar
Man that wiring is impressive. Nice work!
Old 04-16-2018, 01:40 AM
  #36
B20Zer's Avatar
Geezus stripping that wiring, removing the connectors and then cleaning them must have been a yuuuuge job.
Old 04-18-2018, 07:23 AM
  #37
Darkn3s's Avatar
thanks man had to make do with what i had laying around from other harness builds
Old 04-18-2018, 07:24 AM
  #38
Darkn3s's Avatar
it actually wasnt too bad ive done worse with my s2000. but these connectors are actually really simple to remove so that was easy
Old 04-18-2018, 08:26 AM
  #39
footwork mastery
.Grimace's Avatar
yea nice job on the harness! Maybe I should try being useful and doing that to this em1 harness I have.
Old 04-18-2018, 08:49 AM
  #40
Darkn3s's Avatar
thanks man, good thing is that i used the same hole in firewall for the harness and its still somewhat tucked since catchcan is over top. I ended up shortening like 8 wires and extended about 6 using the shortened scraps lol. make sure you test fit before finalizing though
Old 07-31-2018, 06:00 AM
  #41
Darkn3s's Avatar
sorry for lack of update but here are some from when it was in the body shop
cleaning up the wavy quarter panel
made sure to refresh the underside as well
everything gets coated
Old 07-31-2018, 06:16 AM
  #42
Darkn3s's Avatar
So i finally got the car back after 3 months at the body shop (dont ask, the biggest headache ever) So i started to put the body panels back on and decided to clean up the accessory harness that runs to the front clip since the fenders werent fully mounted yet. The bumper will most likely be off alot i wanted it all to look clean underneath as well. Also took advantage of this and and removed unnecessary wires like the wiper reservoir tank solenoid, ac condenser, ac fan and some other emissions things going on in there.
Old 07-31-2018, 10:52 AM
  #43
Darkn3s's Avatar
....aannnnnd the last post for today. Finally got everything put back together and put her on the road for a little photo shoot. I will post up pictures as soon as theyre done. See teasers below
Old 07-31-2018, 11:23 AM
  #44
footwork mastery
.Grimace's Avatar
Car is looking good! I had never had a car painted until recently and it was not a fun experience sounds like you didn't enjoy yours either.
Old 08-03-2018, 10:16 AM
  #45
Darkn3s's Avatar
nah i kept getting the run around on when the car would be completed so 2 weeks turned into a little over 3 months.
Old 08-03-2018, 10:18 AM
  #46
Darkn3s's Avatar
. soo yea i begin to lose interest in the build after the body shop kept the car for a little over 3 months. So after i put it back together and got my photoshoot in i posted up a feeler FS post on facebook and it sold within an hour.. .. guess i may have priced it too cheap but ahh well have another project already in the works. ill post up the photoshoot pics as soon as they finish.
this thing has seen the trailer more times than the actual road
yup this will be my 21522264 s2000 so trying something different.. LS2k coming soon
Old 08-03-2018, 10:24 AM
  #47
footwork mastery
.Grimace's Avatar
out of curiosity what did you sell for?
Old 08-03-2018, 01:30 PM
  #48
LankorDie's Avatar
Sad to hear, but I'm excited to see the S2k build
Old 09-17-2018, 12:06 PM
  #49
Darkn3s's Avatar
she sold for $6k
Old 09-17-2018, 12:07 PM
  #50
Darkn3s's Avatar
thanks yes ill make another build thread on either honda tech or s2ki
BlazeorangeEK
03-18-2013 04:35 PM
allmotor210
01-04-2011 10:56 AM
nickgbmx
06-04-2010 07:56 AM
Quick Reply: The EBP em1 resurrection.. might be slow
