SNOWWHITE V2 build thread
Old Feb 12, 2018 | 07:58 PM
  #126
dwils's Avatar
Default Re: SNOWWHITE V2 build thread
Originally Posted by .Manny.
god damn! That's proper
Originally Posted by ~sp33~
Looks great.
Thanks guys! Just finishes up the rest of the plumbing today. Had to fix the rear coolant hoses that went from the thermostat housing to the back of the manifold. Also had to fix a couple vacuum lines. Now just waiting to order more parts for my fuel set up and we should be good to go!
Old Feb 13, 2018 | 04:55 AM
  #127
ssmrico's Avatar
wowwwww love it!
Old Feb 15, 2018 | 06:53 AM
  #128
dwils's Avatar
Test fitted the slicks I bought last week. Looks good but my fronts are to wide. 24.5x9.5 id be more comfortable with 24.5x8.5 but way to excited! Trying to have this ready by March 18th for Sacramento
Old Feb 22, 2018 | 12:45 PM
  #129
dwils's Avatar
Look what finally came in today guys! Hopefully I’ll have it together tonight and we can finally start this thing
Old Feb 26, 2018 | 07:17 PM
  #130
dwils's Avatar
Finished the final coolant bleeding which means it’s ready for tune!
Old Mar 1, 2018 | 07:51 AM
  #131
ssmrico's Avatar
so nice !
Old Mar 1, 2018 | 11:37 AM
  #132
LankorDie's Avatar
Loved
Community Favorite
So god damn clean!
Old Mar 2, 2018 | 05:02 PM
  #133
dwils's Avatar
Originally Posted by LankorDie
So god damn clean!
Originally Posted by ssmrico
so nice !
thanks guys i appreciate it!
Old Mar 2, 2018 | 05:05 PM
  #134
dwils's Avatar
Hello everyone hope you are all having a good week! Just a heads up i am working on starting a youtube channel. I will post it here once we get the first video up. The content will be of course of the crx and my roommates Fd build that he is currently working on. With that being said stay tuned!
Old Jul 2, 2018 | 08:44 PM
  #135
dwils's Avatar
So this is how the car sits right now. She’s running driving great! I couldn’t be happier with it. I got some parts coming in that I’m excited about and hopefully I can start updating this thread again. So stay tuned. I know I’m not on here every day so bare with me.
Old Jul 3, 2018 | 03:48 AM
  #136
ssmrico's Avatar
looking good
Old Jul 3, 2018 | 01:21 PM
  #137
~sp33~'s Avatar
EFB055
Loving how that bay looks.
Old Jul 3, 2018 | 04:57 PM
  #138
dwils's Avatar
Today I installed a torque mount to try and keep the pressure off the rear mount due to my subframe being for b series because of the rhd.
Old Jul 17, 2018 | 06:35 PM
  #139
dwils's Avatar
Old Jul 18, 2018 | 07:23 AM
  #140
LankorDie's Avatar
Loved
Community Favorite
What did it end up running at the track?
Super clean build, this car looks amazing.
Old Jul 18, 2018 | 09:11 AM
  #141
2x0's Avatar
2x0
10 Year Member
Subbed.
Jesus, how did it take me so long to come across this!
Immaculately clean engine bay and overall build. Much jelly.
Old Jul 19, 2018 | 01:49 PM
  #142
dwils's Avatar
Havent had a clean pass on it yet. Not sure if I’ll have time to take it out to the track any time soon. I am hoping for a track day at the end of the year.
Old Jul 19, 2018 | 03:04 PM
  #143
dwils's Avatar
Originally Posted by 2x0
Subbed.
welcome to my build! Stay tuned I update as much as possible
Old Jul 25, 2018 | 05:58 AM
  #144
2x0's Avatar
2x0
10 Year Member
Originally Posted by dwils
Took her out to cruise 2 Cruz last weekend and had a blast. Had great feedback on her. It was probably the longest I have ever drove her about 100 miles round trip. I have found we have a little over heating issue. I believe it’s really just from heat soak and it’s been pretty hot here. I pulled the manifold off to go get it ceramic coated. Going to build a fan shroud and try to make an intake for the turbo.
I have the same radiator and also ran into some issues with long drives on hot days. Would see 200+ while on the highway. I had to open up some direct air flow to the radiator with the fmic blocking it. Ducting and venting in the bumper, switching to a puller fan, heat wrapping everything and adding a block off plate on the driver's side of the radiator to redirect all of the air through it. Now it stays in the 180's
Old Jul 25, 2018 | 03:50 PM
  #145
dwils's Avatar
Good to know! I like the idea of blocking off the drivers side for more air flow into the radiator. How did you run ducting to the radiator and was it in a crx?
Old Jul 25, 2018 | 04:00 PM
  #146
2x0's Avatar
2x0
10 Year Member
Yes it was.
I had to cut out the front bumper openings as much as possible, and used some sheet metal to direct air flow in from the far passenger side of the grille opening.
I also removed the upper radiator support, and cut a vent in the front of the hood directly in front if the radiator for extra flow. I have a couple of threads I can share if you want any more info or pics
Old Jul 25, 2018 | 04:23 PM
  #147
dwils's Avatar
Yes it was.
Some pics would be awesome if you don’t mind!
Old Jul 25, 2018 | 04:39 PM
  #148
2x0's Avatar
2x0
10 Year Member
Its a little rough, but it got the job done
Old Jul 26, 2018 | 08:03 PM
  #149
dwils's Avatar
thanks for the pictures! Looking over my car the other day my roommate noticed my license plate is cutting off a lot of air to the radiator. So I’m going to work on relocating that to the left side more and see what that does. I really want to keep from cutting into anything at the moment.
Old Jul 27, 2018 | 02:33 AM
  #150
2x0's Avatar
2x0
10 Year Member
Yeah I hear ya! My hood was already junk, so I said eff it I need it to stop overheating!
Just look for any way you can get direct air flow to the rad, or redirect air to it from around the intercooler. Using a scoop underneath the car can work. And definitely try the block off plate if moving your license plate doesn't work.
Also forgot to mention, I added 3/4" hood hinge spacers, and set my fan to come on at 192 with no speed limit. So even if it starts to get hot on the highway, it will turn on and actually help keep it from getting too hot. Having the hood vented and fan on helps to clear the hot air out of the bay and overall decreases heat soak.
