SNOWWHITE V2 build thread
#177
Re: SNOWWHITE V2 build thread
What a headache this car has been. Road block after road block. It was all my fault in poor planning. I guess I never realized how big -16 fittings were. Had to send my radiator back out to get the bung relocated. Will pick it back up on Monday. Then had to exchange some fittings so just waiting for new ones to come in. We are finally so close to being back on the road finally.
#178
COol Beans.. Nice pull on the motor. GOOD LUCK WITH ALL YOUR RACES..
Head gasket = def..
DON"T PROCEED EVAR>> there is no life after that motors with bungs..
Head gasket = def..
#183
I'm not planning on it. Maxwellmercer was running one (water/oil, though) on his turbo B-series, but it didn't work like he had hoped. His thread is over in the FI section. Are you having high oil temperatures, or low pressures or something?
I had another question I just thought of after browsing the thread again - you said new carpet thanks to HMO - I'm guessing they only come across JDM / RHD carpets? Man I would LOVE to get a new-ish set of OEM floor mats for my EG coupe, but they're pretty difficult to come across without a hole worn in them or a big stain or something.
#184
I would call hmo about the carpet. They might have something for you. The one I got wasn’t new it was used but was very clean. At least a lot cleaner than my current one I had in the car.
#186
So I have an update for you guys. I registered for the hot wheels legends tour and was accepted to show the crx. I am so stoked on this! Car has been running great so now I am focusing on the outside of the car trying to clean up some stuff. Stay tuned for updates. Let’s do this 🤟🏼🤟🏼🤟🏼
The following 2 users liked this post by dwils:
#187
My sunroof never worked ever since I owned the car. Finally took the time to diagnose it and found out I was missing 2 of the 4 bump stops. Plus the 2 that I had were broken. Did some research and found gregparts. He 3D prints new ones. Got them on and now I have a working sun roof
#189
Just picked up new door sashes and roof moldings. Have a couple more things on the way/ in the works for the crx. Pretty excited to be back on this thing
The following 3 users liked this post by dwils:
#191
Updated engine bay pic. New downstar hardware went with black beauty washers and gold zinc bolts. Also finally took care of my windshield cowl. Was missing bolts and clips on it before. Now it’s all secured. Still have more parts on the way for this thing. Really liking how it’s all coming together.
#195
Car was down for a minute. Drove it to work one day and had a grind going into 3rd and 4th. I feared the worse. Located a used zc trans from hushperformance. Finally once I received the trans from them decided to take my car apart and pull the trans with the grind apart only to find a broken shift fork. Took apart the hush trans pulled the shift forks and swapped them into the zc trans. Put it all back together and the car has been running pretty good. I am gaining more and more confidence in it
#196
Nice fix. FYI I am 99% sure the shift fork assembly from the other cable D-series transmissions will work in a ZC transmission. I know it will work the other way around (ZC forks in an Si transmission). I had a broken fork in my Si transmission and stole the fork set out of my ZC transmission about 10 years ago and have been driving the Si transmission like that since.
#197
#198
Damn that looks good. Ever think about painting the bottom of the fender black to match the rest of the trim? Just looks outa place.
#199
Today did work on the crx. Finally cleaned out the drain tubes for the sunroof. Pretty sure they’ve never been done before.
Also painted the lower part of the tracklife fenders black so now it matches. Was nice to finally have some time to work on her.
