Troubleshooting oil feed: Oil Restrictor Type or Bad Turbo Oil Sealing Rings?
Old Oct 15, 2017 | 09:37 AM
  #51
2x0's Avatar
2x0
10 Year Member
Default Re: Troubleshooting oil feed: Oil Restrictor Type or Bad Turbo Oil Sealing Rings?
Got the turbo apart. Was all easy going until I got to the reverse threaded nut on the shaft. It was crazy tight, and there was no good way to hold the nut on the hot side. But I got it eventually.
Looking for opinions, is it worth rebuilding this at all? For around $200 I could put in a new balanced shaft and rebuild kit. How much would this turbo be worth if it was rebuilt?
Is this shaft really a lost cause?
Old Oct 15, 2017 | 09:42 AM
  #52
2x0's Avatar
2x0
10 Year Member
Originally Posted by Autoworks
The oil drain should be 5/8 I.D minimum. Double check to make sure that is a 5/8 hose and not a 1/2" hose.
Just double checked and it is 5/8"
Old Oct 15, 2017 | 04:23 PM
  #53
TheShodan's Avatar
Moderator
Turbine shaft is FUBAR'd!!!!
Old Oct 16, 2017 | 02:52 AM
  #54
Autoworks's Avatar
Is that shaft a lost cause...IMO, yes. Is it worth rebuilding(for the sake of resale)...maybe, you may get back out of it what you put in it at some point dollar wise. You did learn in the process so that is reward in itself. You can replace the CHRA, buy a Super core upgraded, or just replace the whole turbo. Those 3 options start at about $500 new in the box compared to $200 spent, that you may get $200-300 back out of at some point, and then be back at square one anyway.
Old Oct 16, 2017 | 08:02 AM
  #55
2x0's Avatar
2x0
10 Year Member
Yeah I'm seriously considering whether I should even bother working on this turbo, or just not waste my time with it.
Old Oct 16, 2017 | 08:19 AM
  #56
Autoworks's Avatar
How much power did the car make? How much power do you ultimately want to make? What type of fuel is it on? Is it a street car/weekend car mostly?
Old Oct 16, 2017 | 09:05 AM
  #57
2x0's Avatar
2x0
10 Year Member
400whp is as much as I'll go on the stock sleeves, and this is what it made previously. It's a street car on e85.
Have been looking at the STC Hunter, but I'm open to other options as well.
Old Oct 20, 2017 | 02:27 AM
  #58
2x0's Avatar
2x0
10 Year Member
Is there any way to tell if this is the same compressor wheel that comes standard on the t3/t4?
I only ask because the PO said it had an upgraded compressor, and it looks like they may have ported inside the housing. I want to make sure if I get a new chra that this housing will still work.
Inducer roughly 2"
Exducer 2.75"ish
Had a number on the back
Does this look alright?
Old Oct 20, 2017 | 04:30 AM
  #59
TheShodan's Avatar
Moderator
Inducer roughly 2"
Exducer 2.75"ish
​​​​​​1) you need a caliper, my friend, a tape measure is horribly vague.
2) you didn't get an upgrade.. "T3/T04E" in the standard Garrett aftermarket cast wheel models are about 5 different wheels used.
3) that compressor cover is HORRIBLY scored. That can't be polished out, and if the inducer is larger than the original you had, you'll just ruin it without it being machined to fit. You cannot be even .02 millimeter off.
Old Oct 20, 2017 | 05:00 AM
  #60
Autoworks's Avatar
You are down to only having a good turbine housing left out of that turbo.
Old Oct 20, 2017 | 09:21 AM
  #61
2x0's Avatar
2x0
10 Year Member
hoping for a big bonus this year so I can get a new turbo I guess...
Old Mar 16, 2018 | 05:25 PM
  #62
2x0's Avatar
2x0
10 Year Member
Just to close out this thread, I installed a new Garrett t3/t4 over the winter. There were some minor differences in hardware fitment but overall it bolted right up.
Drove it in boost today for the first time. Showing no signs of leakage so far, and spooling much better. Can actually hear it spool down after letting off the throttle, and the bov continue to bleed off the pressure. That never happened with the old damaged turbo
Old Mar 16, 2018 | 07:45 PM
  #63
TheShodan's Avatar
Moderator
Way to close this out.. Nice job. Continued success
boostedSI90hatch
May 16, 2007 12:26 AM
ImportMotorSpec
Apr 15, 2005 12:12 PM
Blkteg97
Nov 16, 2004 08:04 AM
QuickHonda
May 24, 2002 09:40 AM
QuickHonda
Apr 17, 2002 08:11 PM
