Old Feb 23, 2017 | 07:27 PM
  #22376
Bently_Coop's Avatar
Steve at Heart
I'll take two LHD and a pair of the radiator bushings.
Old Feb 23, 2017 | 08:38 PM
  #22377
JustOneOrTwoPosts's Avatar
sp33 looks good!
Old Feb 24, 2017 | 04:24 AM
  #22378
ssmrico's Avatar
Old Feb 24, 2017 | 07:47 PM
  #22379
Steve at Heart
Going for a 3pc front end? Which traction bar do you have? How do you like the Hasport Clutch conversion?
I have one on my H2B with CTR Transmission and Competition Clutch, but haven't driven the car yet.
Old Feb 25, 2017 | 08:27 AM
  #22380
ssmrico's Avatar
If I can find a street one yes just tearing down for headgasket and new turbo kit and upgrades , and it's a full race one and I just got it lol not on yet
Old Feb 25, 2017 | 06:48 PM
  #22381
Black R's Avatar
25 Year Member
I'll take two LHD one also pls.
Old Mar 6, 2017 | 06:30 AM
  #22382
Jdawg0420's Avatar
My new hatch it's my second EF, this one has a swapped cluster and I have been trying to figure out the lights I checked all the fuses the dimmer switch but I might be missing something
Old Mar 7, 2017 | 08:55 AM
  #22383
BLU CIVIC's Avatar
Track Advocate
The lights on the cluster?
Old Mar 7, 2017 | 09:05 AM
  #22384
BLU CIVIC's Avatar
Track Advocate
BLU- you should have a throwback sedan meet. Inspire 2leet to get his going.
The last EF Meet I hosted ended with only a handful of people showing and me out our money for a reserved area. It was fun, but that was the last meet I'm doing. Here are a couple pics for the last meets I set up:
And the swap meet I hosted. I actually put on two, but the second one got shut down b/c someone thought a friend of mine was selling stolen parts and called the cops b/c wasn't even the right chassis. After that, I pretty much stopped.
Old Mar 8, 2017 | 06:55 PM
  #22385
Steve at Heart
Hmmm, meets are a fickle thing. Props for trying before. I was thinking more of a get together style then a meet, I'm also a couple thousand miles away too.
Old Mar 9, 2017 | 01:29 AM
  #22386
~sp33~'s Avatar
EFB055
This just in!
Just a print at this stage, still need to do some fine tuning, but it's looking good.
Old Mar 9, 2017 | 02:27 AM
  #22387
Foy Duarte's Avatar
Originally Posted by ssmrico
right lol
should be picking this up soon
how much was that and were can i get one
Old Mar 10, 2017 | 05:00 AM
  #22388
ssmrico's Avatar
hush racing performance
Old May 14, 2017 | 07:02 AM
  #22389
Steve at Heart
Anyone installed B&M solid shifter bushings and have a picture? I put them in, had to cut the end of the shift linkage for it to fit on the rod and the other one at the transmission end is offset.
Old May 15, 2017 | 04:12 AM
  #22390
ssmrico's Avatar
head off a little progress
Old Aug 8, 2017 | 08:22 PM
  #22391
Steve at Heart
Some of you may like this.
https://youtu.be/ywTpqXsbY44
Old Aug 9, 2017 | 05:31 AM
  #22392
B16CRXT's Avatar
Anyone interested in a decent condition 89 DX sedan? Starts up every time, has ice cold AC (system repaired last season) and heat works. The front seats were swapped with a newer civic at some point before I got it and the rails don't all line up so they're kinda janky/not completely bolted down. I wish I could find a set of original blue ones but it's not really worth it to me. The FL fender and driver door skin need to be replaced. Some lady decided she didnt want to be in the turn lane while I was coming up by her and I clipped her front end off. I popped out the fender and pounded the door skin back in place, so it doesn't look as bad, but they should still be replaced or painted at a minimum. It has a battery that's under a year old and tires have plenty of life left. Axles were also recently replaced. Shocks were replaced about 4 years ago.It has a stock D15B2 (not the original...ODO reads around 330K) and leaks some oil from the oil pan gasket as far as I can tell. It also burns an unnoticeable amount of oil. Can't smell or see it behind you, but I'm 80% sure that it does. Clear SC title. Looking to get $1000 for it. Some extras to come with it are a spare DX tranny and a Si final drive/shaft, z6 intake manifold and injectors because eventually I wanted to do a MPFI swap and Si final drive. Also have a set of lowering springs for it. I think they are Sprint springs.
Old Oct 3, 2017 | 06:02 PM
  #22393
Rob.'s Avatar
Removed entire stereo from my crx.. going back to OEM..
I was missing this rear spare tire area sound deadener mat.
washed it lol (not easy to find this part)
[img]https://s1.postimg.org/91p9rwou8f/IMG_0078.jpg[/img
Old Oct 8, 2017 | 09:42 PM
  #22394
zcash's Avatar
I recently had #3 & #8 remanufactured for door mounted seat belt crxs, and will have pillar mounted seat belt crx door seals available soon as well! Also am getting all other discontinued crx seals remanufactured, but will be a while before I have those available!
Old Oct 9, 2017 | 03:51 PM
  #22395
rbwdriven's Avatar
Zcash are you just getting crx doors done or other body style?
I'm asking since I have a crx, hatch and wagon.
Old Nov 3, 2017 | 05:52 AM
  #22396
ssmrico's Avatar
finally motor coming out
  #22397
ssmrico's Avatar
Old Jul 19, 2018 | 03:07 PM
  #22398
Rob.'s Avatar
Had the crx in for an alignment.. but that didnt correct the issues of the steering wheel being off center.
I think the steering rack bushing is toast !
324,000 kms !
Old Jul 19, 2018 | 06:29 PM
  #22399
B16CRXT's Avatar
Isn't that corrected by centering the wheel, then adjusting the toe in/out on each side?
Old Jul 19, 2018 | 06:31 PM
  #22400
Rob.'s Avatar
No as far as I know because of the bushing inside the rack is messed up aligning it wont fix the "offcenter" of the steering wheel.
