I have been trying to figure this out for a while now. I have tried all the recommendations that I was able to find on this forum. I have 12.3 volts to both sides of fuses 24 and 31, fuel pump spools up when I jump 1 to 7 and 5 to 7. I have gone through the steps for checking the main relay and harness for voltage and continuity, harness checked out fine and relay was a little sketchy on one test so I replaced it and still nothing. Is there something I have missed or any other ideas to check?
If you want it I'll pay the shipping as a thanks for the troubleshooting help. Otherwise I'll meet someone near Raleigh or someone can send a shipping label and I'll send it.
I removed the top and bottom ECU lids. The problem was immediately evident. Main capacitor C14, which supplies 5 reference volts to many sensors (e.g., MAP sensor and TPS), clearly blew and damaged the printed circuit board (PCB). The PCB must be cleaned up and the bad capacitor removed to see whether the damage is reparable.
