00 civic auto transmission - problem after rebuild
Old Apr 20, 2016 | 06:06 AM
  #26
tony_2018's Avatar
Fish Twig
Default re: 00 civic auto transmission - problem after rebuild
Not suppose to be "between", it needs to be right up to the "upper" mark.
As eghatch stated, it could be the linear solenoid. If this was rebuilt did they provide new sensors?
Old Apr 20, 2016 | 07:50 PM
  #27
shiguiy's Avatar
will reopen the linear solnoid this weekend to test the resistence and valve movement with click sound. will update.
Old Apr 20, 2016 | 10:14 PM
  #28
shiguiy's Avatar
nope. the sensor is still the original old one
Old Apr 20, 2016 | 10:29 PM
  #29
Former User's Avatar
Default Re: honda civic 2000 auto transmission rebuild problem
Originally Posted by shiguiy
I think so. at least the fluid does not come out. I do not know if I can push further. Actually I hold the whole wheel hub to push in. I can feel the intial resistance due to set ring. maybe I can upload a pic tomorrow.
Post pics of gap between the two inner CV axle joints and the differential.
another werid thing is that I can not push the car down the drive way with slope with engine off and brake down and netral gear. thx
Old Apr 21, 2016 | 10:51 PM
  #30
shiguiy's Avatar
Default Re: 00 civic auto transmission - problem after rebuild
@ronJ: the issue is not about the car-does-not-move any more. I understand the shift cable issue. do you still mean it is related to the shift issue?
thx
Old Apr 22, 2016 | 05:34 AM
  #31
Oh, the car moves now? I missed that. What's the current issue?
Old Apr 22, 2016 | 05:39 AM
  #32
tony_2018's Avatar
Fish Twig
Ron,
The threads were combined. Right now it shifts rough, or rough engagement, or shift points are too high (2500 - 3000 rpm).
Old Apr 22, 2016 | 05:50 AM
  #33
May be worth trying 3 drain-refill cycles with Castrol Import ATF.
Old Apr 22, 2016 | 05:52 AM
  #34
tony_2018's Avatar
Fish Twig
Well...since you swear by it I might as well start using that in my sisters integra.
Old Apr 23, 2016 | 09:20 PM
  #35
shiguiy's Avatar
@Ronj: why do you mention Castrol Import ATFintead of OEM fluid? thx
Old Apr 23, 2016 | 09:51 PM
  #36
It's cheaper than Honda ATF, if you shop around, and also works well for the Honda transmission in my experience.
Old May 1, 2016 | 03:47 PM
  #37
shiguiy's Avatar
@tony_2018: just checked TC and linear solenoid. the TC is new and I guess it is rebuilt ones and it should be ok. The linear solenoid and gasket look ok. the resistence is about 6.3 ohms, not too far away from 5 ohms, right? the valve clicks with movement for the solenoid.
do not know what to check next now.
Old May 1, 2016 | 03:49 PM
  #38
shiguiy's Avatar
@tony_2018: one thing I did notice today. I also open up the lockup solenoid. the click sound is not that strong. So I tried to apply battery voltage to wake it up. the click sound gets louder. Then I drove about 1 mile to the bank and I think the shift is ok. after I came out of the bank, the shift is the same as before. I disconnect the battery before i took apart the lockup solenoid.
any idea?
Tyler Kirst
11
Oct 22, 2015 10:22 AM
kamnamurt
Mar 25, 2014 10:07 AM
imbest123
Nov 3, 2010 10:17 AM
trevorjohn88ef
Transmission & Drivetrain
Nov 5, 2009 08:42 PM
sulmer
May 27, 2008 07:54 PM
