the OFFICIAL TURBO Prelude thread!!!
Old Jun 15, 2005 | 06:20 AM
  #1176
Quade's Avatar
Default Re: Might be getting a turbo, need some help (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">I just wanted to comment about the H22 motor .I have turbocharged just about every kind of motor.And I have to say that the H22 Likes turbos more than any other motor that I have seen.For the amount of boost (say 10lbs) you give it .It makes more power than any other motor I have seen.When I turbo them it looks similar to this .and with A/C and P/S
Modified by RMF at 3:31 AM 6/10/2005
Modified by RMF at 3:39 AM 6/10/2005</TD></TR></TABLE>
What kind of manifold is that?
Old Jun 15, 2005 | 09:30 AM
  #1177
RMF
Guest
Posts: n/a
Default Re: Might be getting a turbo, need some help (Quade)
Thats an RMF .I made the whole kit.Intercooler and all the stuff that goes with it.
http://www.importpowerhouse.co...s.htm
Old Jul 7, 2005 | 06:14 AM
  #1178
xxredpreludesixx's Avatar
i already asked and know it would be ok to run 7psi or so on a stock H23 but, what about detonation is there any chance i would get bad detonation? i would have my turbo professionally installed, and tuned what are my chances of getting detonation? as for building engine well after i get the turbo i would plan on building the bottom end up.
Old Jul 7, 2005 | 07:51 PM
  #1179
ralpheezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">Thats an RMF .I made the whole kit.Intercooler and all the stuff that goes with it.
http://www.importpowerhouse.co...s.htm</TD></TR></TABLE>
Can someone get that manifold seperately or just in the kit?
Will it only fit the T3 turbo (it says T3 kit on that site) or can it fit other turbos like the T3/T4 hybrid?
That's a freaking nice manifold by the way.
Old Jul 10, 2005 | 10:20 PM
  #1180
RMF
Guest
Posts: n/a
Default Re: Might be getting a turbo, need some help (ralpheyizzle)
Yes ,You can buy the whole thing 1 piece at a time if you want
Old Jul 11, 2005 | 06:59 AM
  #1181
c61lude's Avatar
here mine
-stock h22
-onefab series 1 manifold
-precision sc-61
-aem ems 30-1020 tuned conservatively
buncha other stuff that's not really relevant
Old Jul 22, 2005 | 08:16 AM
  #1182
EOSpeed's Avatar
What kind of horsepower are you getting with your setups???
Old Jul 22, 2005 | 09:39 AM
  #1183
EOSpeed's Avatar
Default Re: (jnet)
Your piping is chromed or polished? If chromed did it have that rainbow effect?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnet &raquo;</TD></TR><TR><TD CLASS="quote">Here's my car to be referenced if need be..
'95 Prelude Special Edition
JDM H22A swap
Drag 3 Turbo Kit
T3/T04e
Race Engineering 9:1 pistons
TotalSeal Piston Rings
Crower rods
ARP Stud Kit
RC 780CC injectors
TurboSmart Boost controller
hondata s100 w/ boost
5zigen fireball exhaust no cat
352 fwhp @8500rpm
262 ft-lbs @6700rpm
12psi
Modified by jnet at 9:48 AM 12/19/2004</TD></TR></TABLE>
Old Jul 22, 2005 | 11:30 AM
  #1184
Earthworm Jim's Avatar
Nice pictures people
Old Jul 22, 2005 | 01:17 PM
  #1185
lude of pre 2.3's Avatar
Default Re: the OFFCIAL TURBO Prelude thread!!! (RAB)
im pretty sure that the weakness in the h22 and 23 is the thinness of the cylinder walls. ive looked at many motors fro dsm's and nissan and almost all of them have more room between the cylinders
Old Jul 22, 2005 | 05:30 PM
  #1186
stinger's Avatar
Default Re: the OFFCIAL TURBO Prelude thread!!! (lude of pre 2.3)
yea but dsm's are junky crankwalking bastards!
Old Jul 25, 2005 | 11:25 AM
  #1187
prelude760's Avatar
me and a buddy of mine are putting a cutsom turbo kit together consisting of a ft2871r turbo with a .57 trim. does anyone know of a good tubular manifold for it and where i can get it? if not i guess ill go for the cast iron but i need to find it first...HELP
reid
Old Jul 25, 2005 | 12:03 PM
  #1188
EdgardPreludeTurbo's Avatar
Default Re: (prelude760)
well this is my turbo prelude, i am from venezuela, it has a F22 engine in it.
Old Jul 25, 2005 | 02:24 PM
  #1189
graphic's Avatar
Default Re: (EdgardPreludeTurbo)
heres mine:
Old Jul 25, 2005 | 04:39 PM
  #1190
stinger's Avatar
graphic whats your setup
Old Jul 26, 2005 | 05:21 AM
  #1191
kamAccord's Avatar
Wow! This thread has a lot of good info. Thanks!
Old Jul 26, 2005 | 09:47 AM
  #1192
john d
Guest
Posts: n/a
Default Re: (kamAccord)
HERES MINE- 400whp/310wtq
Old Jul 26, 2005 | 10:47 AM
  #1193
EOSpeed's Avatar
Default Re: (john d)
What is your setup???
Old Jul 26, 2005 | 11:26 AM
  #1194
c61lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude of pre 2.3 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure that the weakness in the h22 and 23 is the thinness of the cylinder walls. ive looked at many motors fro dsm's and nissan and almost all of them have more room between the cylinders
no it's not, when was the last time you saw the cylinder walls on a stock h22 crack under boost?? they don't it's the ring lands or the rod/rod bolts. The issue with the stock sleeve is they don't allow for forged pistons because the expansion rate of the sleeve is different then that of the piston thus creating piston to sidewall contact
Old Jul 26, 2005 | 12:33 PM
  #1195
graphic's Avatar
Default Re: (stinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinger &raquo;</TD></TR><TR><TD CLASS="quote">graphic whats your setup</TD></TR></TABLE>
sleeved h22 stock 87mm bore
stock head, stock IM, f-max log manifold t3/t4 "60" trim turbo w/ .63 a/r hotside
750 cc injectors
msd 6a box, ss blaster coil, 2.25in dumptube, 3in exhaust w/ testpipe, open dumptube, str cam gears -3in, 0 ex.
total timing 19 degrees
18psi boost
all controlled by NEPtune
as you can see there is a **** load of more power to be made once i can find some time to upgrade my puny 2.25in dumptube and maybe even switch to a EL
BTW nice setup john, how big is that t4 again?
we need some NEPtune stickers for our cars man.. get me a logo and i can print them up..
Old Jul 28, 2005 | 02:41 AM
  #1196
1epmugenlude's Avatar
Default Re: the OFFCIAL TURBO Prelude thread!!! (mugenbb6)
[IMG][/IMG]
Here is a pic of my lude's set up
[IMG][/IMG]
[IMG][/IMG]
Modified by 1epmugenlude at 10:37 PM 7/28/2005
Old Jul 28, 2005 | 07:50 AM
  #1197
EOSpeed's Avatar
Default Re: the OFFCIAL TURBO Prelude thread!!! (1epmugenlude)
Really sweet!!!! What kind of couplings are those that you are using???
Old Jul 28, 2005 | 08:44 PM
  #1198
they are the cheap ones that came with the greddy kit....
Old Jul 29, 2005 | 09:16 PM
  #1199
EOSpeed's Avatar
Default Re: (1epmugenlude)
is the piping chromed or polished??? If they are chromed did they rainbow or change colors????
Old Jul 30, 2005 | 01:51 PM
  #1200
stinger's Avatar
Default Re: (EOSpeed)
i have chrome, i would not do it again. It holds in a lot of heat, no it has not changed colors or rainbowed.
