Nations second fastest street all motor OGS eg hatch partout
Nations 2nd fastest OGS Street all motor eg hatch part out!
All parts are located in Suffolk county LONG ISLAND,NY
Call or text me at 516 342 0318
$3000
1992 Honda Civic vx (lightest shell)
6 point cromoly roll cage
Front bumper w/ quick release (quik-latch)
Front bumper w/ block off plates
Engine bay was painted in 2014 si nighthawk black pearl
Integra dash and door panel retrofit
Fal 1/4 glass
Carbon fiber hood w/ locks and w/cutout for intake
Tokico blue struts
Brake booster delete
Skunk 2 rear lower control arms
Stock Steelies
No hatch or wing included with shell
Bottom end: $4500
H23 55mm mains 90.5 mm bore inline pro sleeved block shaved for H2b using DSS stage 3.9 axles
Block clearances for 99mm stroke
Brand new Honda K24 crank
Rosko Racing K24 crank modified to fit h22.. which he no longer offers
Ks tuned balance shaft delete
Carrillo A spec rods.
Cp max dome compression single ring pistons
Honda oem pink bearings
New Honda oil pump
Ati race dampener
Oil pan
H22 cylinder head
NO CAMS OR CAM GEARS $2500
Originally Randy Owens and personally worked on by brad at RLZ
Rlz CNC cylinder head refreshed by WES. +1 mm Intake valve std exhaust
Custom machined rockers by Randy Owens
New valve seals
New magnesium bronze valve guides
New ferrea valves
New double valve springs and retainers
New Valve locks
Trans $2000
Jdm del sol sir b16 trans
Liberty Faceplating
Quaife lsd
Speed factory Scha
$800
Driveshaft shop stage 3.9 axles
$2000
Randy Owens custom out the hood h2b manifold with accufab 90mm throttle body with Ford Mustang tps and map and IAT sensors
$2000
Randy Owens custom 4-1 header with burns stainless collector fender exit
$800
Evo H2b kit with solid inserts /bushings also/ halfshaft/ARP flywheel bolts/post mount and QSD spacer to run whatever clutch/flywheel combo you want
$450
T1 h22 cam trigger kit
$600
AEM COP kit with OEM si coils
$125
AEM wide band part #30-4100
$1000
exedy b series twin disc clutch with lightweight flywheel
$1100
Kaizenspeed rear trailing arm kit everything included
$300
Custom kinsler ITB airbox
$800
weld racing 13x10 bead lock drag rims with 13x9.5 Mickey Thompson slicks
$1100
Weld one piece skinnies with M & H racemaster tires
$500
M factory Part # MF-TRS-02B
brand new never used M factory 4.7 B16 final drive
$800
AEM V2 part # 30-6040 programmable ECU with custom ecu tray
$550
FAL hatch lexan with custom drag wing painted si night hawk pearl with custom supper brace and own wing for added support.
$200
Water filled oil pressure and coolant temperature gauges and tachometer gauge
$250
Honda meizer electric water pump kit with b series mounting bracket, Inlet and outlet fitting, h series water pump with fins cut, thermostat and rad hose, relay, and switch .. just install and turn on.
$300
turbo start lightweight 16v agm battery with Schumacher 16v 25amp battery charger.
$450
NRG tech traction bar with 2 weight bars filled with lead shot and extra unopened bag of lead shot
Carbon fiber hatch trunk-$650
South Bay fuel injectors 1000cc -$350
Shift linkage -$100
Golden eagle b series scatter shield-$180
Catch can setup with AN lines - $200
Skunk 2 pro 3 cams - $500
Crower cam gears -$150
H22 arp Head studs-$100
Valve cover with 4 welded bungs -$200
Catch pan -$100
Fal radiator and fan -$100
2 kirkey seats $175/each
1 gallon fuel cell with filters/lines -$250
Bosch 044a fuel pump -$100
Modified h2b harness-$150
Battery relocation kit-$80
30lb lead **** ballast -$50
Skunk 2 h2k adapter -$100
fv8s
10-06-2010 12:54 PM
tannerLSt
04-13-2006 02:51 PM
