FS: Autometer oil pressure gauge w/ braided line.
Never been used...its the mechanical kind that the oil runs up to the actuall gauge. Thats why I bought
the braided line with it to (the braided line is still in package un-opened). Also have gauge pod for a G2 Integra.
Make offer...willing to trade for a electrical oil pressure or water temperature gauge.
Re: FS: Autometer oil pressure gauge w/ braided line. (RATEDR)
How long is the cable? The cable and guage are BSPT right? Do you have a Tee also?
I'm not sure how much these things cost, but I've got $40 to spend. I was going to get one from Auto Zone, but they need an NPT - BSPT adapter.
You can e-mail me if you'd like.
Thank You,
Karl Erickson
Karl.Erickson@nextel.com
Thank You,
Karl Erickson
Re: FS: Autometer oil pressure gauge w/ braided line. (WOTTEG)
you will also need an NPT-BSP adaptor no matter what, and to do it right, you will need 2
*1 to adapt the T fitting to the block from 1/4NPT(F) to 1/4BSPT(M) (or whatever size you use)
*1 to adapt the stock oil pressure sender which is a 1/4BSPT (M) so if you use a T you might need something like a 1/4BSPT to 1/4NPT female to female coupler adaptor. I used a fuel pressure sending block which has a
-6an on each side and the block is tapped for a 1/4NPT
Re: FS: Autometer oil pressure gauge w/ braided line. (stizzit)
Does your 91 Teg have a 1/4" BSPT female hole for the Oil pressure switch to use? I think my 2000 uses a 1/8" BSPT.
I just went all over town during my lunch break looking for two NPT to BSPT adapters; no luck. I still have two stores to look at though.
I'm actually trying to set it up where there is tubing between the block and the 'T'. And since the tubing usually comes with different sized NPT fittings, i should be able to choose from a couple of NPT to BSPT adapters for the block.
Thanks,
Karl
Thanks,
Karl
