Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tranny fluid help please
Old Apr 3, 2008 | 06:19 AM
L8APX's Avatar
Default tranny fluid help please
I've searched, lots of noise out there on this topic.
I have a trackday on Sunday. Just got the car in yesterday. I don't think the tranny fluid has been changed in a looong time.
from searching the consensus seems to be either Honda MTF or GM syncromesh. so I think syncromesh comes in several varieties, with and without slip modifiers.
It's a Y21 5speed with a stock ITR LSD.
any recommendations? cars going in the shop tomorrow for brake/clutch bleed, tech inspection, lubricants change, etc.
thanks!!
Old Apr 3, 2008 | 06:23 AM
thawley's Avatar
Default Re: tranny fluid help please (L8APX)
You don't need a slip modifier with the OEM/helical LSD, that stuff is for clutch type LSDs.
I use Honda MTF.
Old Apr 3, 2008 | 07:01 AM
Lo-Buck EF's Avatar
Default Re: tranny fluid help please (thawley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley &raquo;</TD></TR><TR><TD CLASS="quote">You don't need a slip modifier with the OEM/helical LSD, that stuff is for clutch type LSDs.
I use Honda MTF.</TD></TR></TABLE>x2
Old Apr 3, 2008 | 12:19 PM
BrianZ's Avatar
Default Re: tranny fluid help please (Lo-Buck EF)
X3
Old Apr 3, 2008 | 12:52 PM
mc-integra111's Avatar
Engine oil works fine too. I use Valvoline Durablend 10W-30 (same weight as in the engine). I was told not to use the full synthetic in the tranny when using brass syncros.
Old Apr 3, 2008 | 02:53 PM
Austin's Avatar
I use Honda MTF in the Type-R tranny, at one time it had "normal" oil in it, and it made weird noises during slow speed turns.
Old Apr 3, 2008 | 03:42 PM
slammed_93_hatch's Avatar
Default Re: tranny fluid help please (Austin)
i never had good luck with the MTF from honda. It would be fine for 3 or 4 laps then it would start to grind on all the shifts.
I started running redline MTF and it was fine for the whole session.
isaacson06
Aug 23, 2007 02:50 PM
97turboteg
Sep 7, 2006 10:30 PM
enigma94
Jul 11, 2006 02:10 PM
SFWDcoupe
May 19, 2006 11:06 AM
crx(gator)
Jan 13, 2002 03:25 PM
