Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Solid 4 piston caliper bleeding process
Old Apr 10, 2008 | 07:02 PM
rdssk8rcs1's Avatar
Default Solid 4 piston caliper bleeding process
Any special way of bleeding them?
Old Apr 10, 2008 | 08:41 PM
spets's Avatar
Default Re: Solid 4 piston caliper bleeding process (rdssk8rcs1)
Do they have like four bleeding nipples or something?
bleed em like usual....
Old Apr 10, 2008 | 08:50 PM
ekim952522000's Avatar
Default Re: Solid 4 piston caliper bleeding process (spets)
Most have 2 one per side.
Old Apr 11, 2008 | 06:09 AM
rdssk8rcs1's Avatar
Default Re: Solid 4 piston caliper bleeding process (ekim952522000)
Well i wasnt sure if there was an easier way to work the air out of the caliper with it being so big and having so much internal area to it vs a regular 1 piston sliding caliper. It only has one bleeder at the top of it
Old Apr 11, 2008 | 06:52 AM
117's Avatar
117
What kind of caliper? My Wilwoods have 2 bleeders, one per side. I bleed like normal, but now I have 6 spots to bleed instead of 4.
Old Apr 11, 2008 | 07:15 AM
MSchu's Avatar
My Name is Nobody
Default Re: (117)
if it has four nipples or two that are opposing, you only need to bleed the upper facing nipples
Old Apr 11, 2008 | 07:48 AM
thawley's Avatar
Default Re: (MSchu)
Right. Never, never, NEVER use the bleeders at the bottom for anything. Only the ones on the top. (Air rises...)
So if the caliper has four bleeders, treat it as if it only has two (the ones at the top). Start with the inside bleeder – closest to the master cylinder – get all the air out. Then move to the outside bleeder.
Move to the next caliper. Repeat.
When in doubt, think like an air bubble...
Old Apr 11, 2008 | 07:49 AM
rdssk8rcs1's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">if it has four nipples or two that are opposing, you only need to bleed the upper facing nipples</TD></TR></TABLE>
My only has one its a rotora kit. SO no special trick in getting the air out of them? Just a lot of bleeding?
Old Apr 11, 2008 | 07:55 AM
kommon_sense's Avatar
Only 1 bleeder? That really doesn't sound right? I would expect a 4 piston to have 2 pistons per side which would be a bleeder per side.
The way I've bled dual bleeders in the past was to open both bleeders with lines on both bleeders. Keep pumping the pedal until fluid comes out of both bleeders. Then tighten bleeder #1, and do normal bleeding on bleeder #2. Once that is good, tighten bleeder #2, and do normal bleeding on bleeder #1.
This method seems to do the trick on new calipers that will have substantial air in the lines.
If you do really only have one, then I would expect the normal bleeding procedure to work just fine.
Old Apr 11, 2008 | 11:32 AM
JW racing's Avatar
My Rotora brakes have 2 nipples per side on the top.? which kit do you have?
As per the instructions, Right outer, Right inner, left outer, left inner
Call rotora and check , they should have 2 each side.
Old Apr 11, 2008 | 04:54 PM
rdssk8rcs1's Avatar
Default Re: (JW racing)
I have the hardline at the bottom that connects the 2 seperate sides of the caliper but Im pretty sure the only bleeder is on the top outside. Ill definitly give it another look and another try of bleeding. I thank you all for teh insight and ill get back to you asap
regal1975
Mar 28, 2014 06:02 PM
dohcef
Jun 5, 2009 08:00 AM
essex
Dec 20, 2007 05:11 AM
david90
Jul 7, 2004 10:47 PM
highmilehatch
May 23, 2003 10:35 AM
