Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Quick Ground Control spring question
Old Jan 16, 2003 | 04:59 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Quick Ground Control spring question
The spring reads GC180.64.44. I assume this is a 180lb spring?
Old Jan 16, 2003 | 07:46 PM
96 SOHC VTEC's Avatar
Default Re: Quick Ground Control spring question (SkyeC)
As far as I know that is correct.
Old Jan 16, 2003 | 10:03 PM
Tyson's Avatar
Default Re: Quick Ground Control spring question (96 SOHC VTEC)
no, its a number identifying the car the springs were made for, NOT the actual spring rates. call gc for the spring rates, usually if you ask them right they will tell you.
Old Jan 17, 2003 | 12:32 AM
travis's Avatar
Default Re: Quick Ground Control spring question (Tyson)
The GC180.64.44 is 180mm long, 64mm inside diameter, and 44 Newton-meter spring rate (about 250 lbs).
Old Jan 17, 2003 | 01:12 AM
Art Vandeleigh's Avatar
Default Re: Quick Ground Control spring question (travis)
...and 44 Newton-meter spring rate (about 250 lbs).
are you sure about that conversion? can you provide your conversion formula.
Old Jan 17, 2003 | 03:22 AM
Eee Pee's Avatar
Default Re: Quick Ground Control spring question (Art Vandeleigh)
Eibach makes it so simple, why would ground control make it more complicated?
Old Jan 17, 2003 | 07:55 AM
turbohappy's Avatar
Default Re: Quick Ground Control spring question (Eee Pee)
I agre...that is pretty idiotic!
Old Jan 17, 2003 | 12:38 PM
oioioi's Avatar
Default Re: Quick Ground Control spring question (happycorepuppy)
are those legal for scca solo 1 street prepared class?
Old Jan 17, 2003 | 12:40 PM
.RJ's Avatar
.RJ
Default Re: Quick Ground Control spring question (oioioi)
Yes. Your shocks/springs are free, provided the mount to the original mounting points (i.e. You cant change geometry)
Old Jan 17, 2003 | 01:05 PM
Doctor CorteZ's Avatar
those numbers identify the GC kit
if you order ERS springs they have the correct format
Old Jan 17, 2003 | 01:07 PM
Lo-Buck EF's Avatar
my gc's have the rate printed on the spring. guess urs don't
Old Jan 17, 2003 | 02:09 PM
travis's Avatar
I'm sure about the length/height/rate part. I'm also sure that they are 44 N-m, but I'm not sure about the conversion off-hand. I took it from a site that listed the conversion factor as 5.7. I didn't double check to see if their conversion factor was correct
[Modified by travis, 6:29 PM 1/17/2003]
Old Jan 17, 2003 | 04:14 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Well, that makes me feel a bit better, I ordered the Integra Ground Control kit for my 92 Civic w/ ITR shocks and always wondered why they had sent me some not-so-stiff springs. I'll have to grab the number off the fronts tomorrow and give Ground Control a call, I suppose. Or, does anyone know the rates GC sends out w/ their Integra kits?
FWIW, I plan on autocrossing this year and was going to step the rates up a bit (around 375 or so is the most ITR shocks can run, I've been told) and run the GC upper mounts for increased travel until the ITR shocks start to die, then get some Konis and stiffer springs.
Old Jan 17, 2003 | 07:23 PM
HondaCivicEx98's Avatar
New User
I believe those are Newtons/mm.
Like some Japanese supension are listed 8k Front and 6k rear. What really means is 8kg/mm and 6kg/mm
if we want to convert that in to pound/in, than some conversion contant is needed .
1 kg=2.2pound
1in.=25.4mm
8kg would then equal
8kg/mm*2.2 pounds=17.6pounds/mm
17.6 pounds/mm*25.4mm=447 pounds/In.
Using the same concept then here are the contanst for newtons
1 Newton= .225 pounds
1in. = 25.4mm
then 44 newtons is equal
44/mm*0.225=9.9 pounds /mm
9.9 pounds/mm* 25.4mm= 251.46 pounds/in.
Or we can just multiply to 5.7 constant for ease of calculation
I think this measurement are pretty common in europe while the USA uses pounds.
dcsports
Suspension & Brakes
11
Dec 31, 2016 08:57 AM
EK k kay
Suspension & Brakes
Mar 13, 2006 09:39 AM
deviant1
May 1, 2004 03:33 PM
Tweakmeister
May 31, 2003 02:33 PM
743power
Mar 20, 2002 07:25 PM
