Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
OT: Emissions help for Street/Track Car
Old 06-30-2004, 09:48 AM
RacerBowie's Avatar
Default OT: Emissions help for Street/Track Car
Ok, '91 Miata, 171,000 miles, fails NOx on emissions.
Already put on a new O2 sensor and a used cat (was on a gutted one).
Blows 1400 ppm, needs to be under 1100 ppm.
What are some fairly easy things to try to keep this sled on the road?
To be on topic, we do our HPDEs in this car.
Thanks guys,
Bowie, who really can't afford this crap.
Old 06-30-2004, 10:35 AM
Spade's Avatar
Default Re: OT: Emissions help for Street/Track Car (RacerBowie)
Exhaust wrap around the header and cat to help generate heat faster.
Or a NEW cat.
High flows go for 50 bux on Ebay.
Old 06-30-2004, 10:39 AM
Brian*'s Avatar
It could be running lean, is there any way you can add a touch of fuel?
High NO generally is caused by lean fuel/high combustion chamber temps. I had the problem with my Si, added a little fuel with a VAFC, ppm went from 1220 to 190
Brian
Old 06-30-2004, 10:51 AM
New User
John's Avatar
Well, if the car is burning a stoic A/F mixture, the problem is most likely carbon buildup in your EGR system. It's possible your cat could need replacing, but normally you'll be high on CO as well. I say this as I did a lot of research after my beater failed emissions on the NOx count 10 days ago.
Old 06-30-2004, 10:53 AM
JoelG's Avatar
Default Re: OT: Emissions help for Street/Track Car (John)
less ignition advance. had a buddy that had the same prob. with his SM and I'm pretty sure the fix was setting timing back to the factory spec.
Old 06-30-2004, 12:44 PM
RacerBowie's Avatar
Default Re: OT: Emissions help for Street/Track Car (JoelG)
Cool, thanks to all.
Here is the plan: Set the timing back to 10 degrees (at 14 now), replace PCV, and up the fuel octane from 89 to 93 for the test.
That oughta bring the combustion temps down.
Hopefully it will pass this time, this is getting old.
Bowie
Trick311
09-23-2010 08:18 AM
92civicfreak
50
12-03-2007 03:03 PM
kenny7
05-11-2007 09:13 AM
mintscorpion
19
01-20-2006 04:27 PM
Splangtastic
06-19-2003 01:30 PM
Quick Reply: OT: Emissions help for Street/Track Car
